Question about Nintendo DS Lite Console
I have a ds lite that i am trying to put on and i having trouble taking that gold looking thing off and putting it threw the whole.i need help
    Problem Solver:
  • 5 Answers
Errr
Posted on Sep 07, 2009
Ds not Reading games
1 make sure to put it in the right way
or if the ds game is dirty broken or has water ion it it wont read so take tissue and rub the gold part with water then take a dry one and wipe it off
Feb 10, 2010 | Nintendo DS Lite
DS Lite, the top screen goes black when opened the whole way when the game is opened to a 90 degree angle the screen is clear and works fine.
There are a few things that could have happened, the most likely that one of you cable clips is loose, and when you open it fully, it pulls it out just enough so that the connection is lost.
Your going to need to open your DS, (the forms at www.powergamingparts.com are the best forms to find these instructions) then just disable your clip, and reinsert it, and then close the clip, and put you DS back together. Just ask if you need any additional help.
Sep 27, 2009 | Nintendo DS Lite Console
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
Put game into action replay and it says insert game card help
I had the exact same problem as you, and I solved it. The only way to do it is to keep inserting and taking out the game card, and blowing into the DS card slot and the gold things on the lower back of the game card. After doing this about 3-5 times, the action replay should finally get the message that there is a game card in the slot. Hope this helps!
--Josh
Apr 12, 2009 | Nintendo DS Lite Console
Ds lite games not playing?
have you tried taking the game out and in about 10 times when the ds is turned of
Sep 08, 2008 | Nintendo DS Console
Crack in DS
I have tried plenty of ways but this plastic cant be pasted easily and the hinge crack the junction again so basically you need a new hinge piece, something saddly cant be bought alone, you need to buy a whole shell.
If not under nintendo 1year warranty, the best thing you can do to kill this problem is take the DS to a videogame repair service to replace the shell before the top screen or the whole DS suffer more damage. You can also consider to buy and change the shell by yourself. The bad new is anyway you need some money to repair it.
You can use the DS carefully meanwhile the top part dont get completelly out of place.
Jun 17, 2008 | Nintendo DS Lite Console
DS lite left in washer
Take the battery out right away and let it air dry in a window or under a light. dont use a fan or hair dryer. let it sit for about 2 maybe 3 weeks and put the battery back in it and it may work. you dont want the battery in it while there could be some kind of water in there still becuase it could cause a short on the mother board.
May 19, 2008 | Nintendo DS Lite Console
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
May 07, 2008 | Nintendo DS Lite Console
Touch screen broken
i would say that the screen got cracked
Feb 16, 2008 | Nintendo DS Lite Console
My Nintendo DS Lite keeps freezing. It will play for a bit then freeze. When I turn the power off then play it, but then freezes again! Any answers?
Try this as it will restore the DS to factory settings.
Remove the battery cover off the back of the unit. (One small Philips screw.)
Remove the battery.
Leave the system without the battery for 10-15 minutes.
Replace the battery.
Re-install the battery cover.
Dec 19, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
15 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
