Question about Maytag MSD2756G Side by Side Refrigerator
Ice maker is not making ice and the refrigerator won't go colder than 55
    Sergeant:
    Champion:
  • 214 Answers
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 13, 2009
Ice maker is not functioning. no ice being made.
There are a few basic things you need to make ice. First is a refrigerator that is cold enough. Most ice makers in refrigerators need 15 degrees or colder in the compartment that the ice maker is located. Second, a functioning water valve and ice maker. What model of refrigerator do you have?
Mar 24, 2016 | Refrigerators
My ice maker on Maytag MF12468AE stopped making ice. When I add water to the tray, the cubes form but are not ejected. Is the the water valve bad or is the entire ice maker itself bad?
The ice maker is bad and they have been discontinued by the manufacturer. Luckily, there is a replacement part that works in your machine, part number W10477228. The reason I say its bad is because it should have atleast ejected the ice that was made when you poured water in it if it were working properly. The only other thing it could be is that the temperature is not cold enough in the ice maker area, which is 10 degrees F or colder. If the temperature isn't at least that then the ice maker won't cycle at all.
Jun 05, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
I love my refridgerator except for the fact it doesn't make enough ice.I was wondering if there is a setting to adjust the amount of ice it makes..I had a service man to come out and there is nothing wrong...
mrs. justice u should have a setting knob that says freezer colder and by adjusting that knob a little making the frezzer colder so the ice frezzes faster. the faster it frezzes the faster it will dump making more ice. but if that dont work then that box should be equiped to have the more up to date one that has a fan in the ice maker that makes it colder and makes ice faster.. remeber the colder the faster the ice should make. ok try that. later gator.
Feb 22, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool fridge with the freezer on top. The ice maker is not making ice quickly. How can I fix this?
Good day,
As a general rule refrigerator ice makers don't really make ice cubes very fast.
Things that could increase the production are.
1. Set the freezer to a colder setting. That control is usually on a whirlpool is called an air control.
2. Setting the refrigerator control colder, while also help since setting it to a colder setting will actually make both compartments colder.
3. The ice maker produces ice when it's internal thermostat reaches approx. 14 degrees.
You have no control of that function.
4. If the cubes are on the small side, the water valve on the back bottom of the machine may need to be replaced.
5. Along that same line, the water supply line from the house and it's fittings could be starting to restrict, not supplying enough water pressure.
The line, unless plastic, and the valve would need either be removed and cleaned or replaced with new.
Dec 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker won"t work
Give it at least 24 hours to get started. May need to turn freezer colder also.Make sure Arm on ice maker is not locked in up position. I don't know what jump means. If it has been in frig for a long period with out water but still going through the motions there could be other problems. But if it was just hooked up give it time to get going.
Jun 28, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore ref. side by side, ice maker does not make ice. Model # 106.56534400
check the temperature inside of the freezer and if its colder then 17 degrees then you have to thzaw out the line that dumps the water into the ice maker.
Feb 25, 2009 | Whirlpool GD2SHGX Refrigerator
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Installed replacement Icemaker but will not dump new ice...
Either your freezer is not cold enough or you got a defective ice maker. It needs to be 15 degrees or colder to make ice. The water may be frooze but not cold enough to close the internal thermostat inside the ice maker. If your freezer is colder that 15 degrees, take the ice maker back to Sears, you got a lemon. Good luck!, Mack
Jan 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not dumping ice
Make sure the freezer is at least 17 degrees or colder (colder is better). If you have a square cover on the end of the ice maker see if you can pull it off and press on the gear face (don't turn just press). That may clean the electrical contact springs and get it working again. Basically if ya got water, 17 degrees or colder you will get ice. Other than that the ice maker motor module is likely bad (broken gear, etc.). Pretty common.
Aug 17, 2006 | Frigidaire FRS26KF5C Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
66 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
