Agitator wil not move makes a growling sound but all spin cycles still work
    Problem Solver:
  • 18 Answers
Either the transmission is bad, or more likely the agitator dogs are broken. If you pull the top pieces from the agitator you can see the agitator dogs and tell if they are intact or broken. If they are good, the transmission might be bad. The only other thing will depend on if the machine goes through the wash cycle to the rinse and spin without ever agitating, or if you have to manually move it. If you have to manually move it, your timer is probably bad.
Posted on Sep 06, 2009
Maytag Model LA610 - Newton - old style counterweight transmission (mfgd.1981)
check motor coupler, agitator spindle, drive block and shaft, cam dogs and motor windings
Mar 23, 2017 | Washing Machines
Agitator just clicks when it should be moving. Will not move in wash or spin cycle. Please advise.
Agitator has 4 Teeth - Dog Teeth I Beleve the name is in top part of Agitator. Take softener cap off top of Agitator. There is a plastic cover under softener cap. You need to remove plastic cover then you will see 4 teeth that lock into the agitator replace all 4 teeth make sure you put the teeth back in the same way or it won't work. Old teeth are rounded and won't grab Agitator anymore. Job not hard.
May 17, 2010 | Washing Machines
Whirlpool LSR7233EQ0 Squeals
There are dogs in the agitator and they can vibrate and growl at times. An easy check for this is to turn the top of the agitator either way briskly and see if the dogs engage. If they do, just lube them sparingly with lithium spray lube, silicone spray or Vaseline. Also make sure while the agitator cap is off that the agitator bolt on top is sufficiently tight.
Your squealing sound is the result of a worn drum brake which affects both the spin and brake function of the inner tub. For my step by step detailing access to this part, take a look at my tip on disassembly here\/\/\/
http://www.fixya.com/support/r4355933-washing_machine_repair_direct_drive
Mar 24, 2010 | Washing Machines
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
Nov 29, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
