Question about Air Tools & Compressors
Don't have the owners manual for a polyquip gas powered honda engine GX160 5.5 hp air compressor
  • 388 Answers
Click this link then click on "Download", the download is free: http://www.ebookspdf.com/automotives/honda/1829/honda-gx120-gx160-owners-manual/
Posted on Sep 08, 2009
Govoner arm came off how to put it on in the right place
thats a honda engine
Search Results
Honda Engines ' GC190 Owner's Manual
engines.honda.com/parts/ownersmanuals/gc190 Download or purchase Honda Engine owners' manuals for the GC190.
Honda Engines ' GC190 4-Stroke Engine ' Features, Specs, and ...
engines.honda.com/models/model-detail/gc190 Official specs and features for the Honda GC190 OHC engine. ... is a small four-stroke gas engine designed for premium residential use. ... Owners Manual.
[PDF]honda 6hp gc190 repair manual.pdf
www.publicwalls.org/honda/honda-6hp-gc190-repair-manual.pdf
Apr 08, 2016 | Horizontal Engine 6 Hp Ohc Gc190mha2
Regulator broken honda 5.5hp
HONDA 5.5 ENGINE DOESN'T HAVE A REGULATOR ----ITS JUST AN ENGINE .SO WHAT ARE YOU TALKING ABOUT?
Mar 27, 2014 | Honda Quincy 17 - Gallon Air Compressor...
How much oil for a quincy compressor model #216
What type of gauge belongs on the side of a 216 quincy compressor?
Also were can i locate one?
Thank you!
Tom
Mar 24, 2013 | Honda Quincy 17 - Gallon Air Compressor...
Dewalt D55275 gas powered compressor , when press gets above 60 psi engine sputters and dies, have replaced carb and pilot valve with no luck
when its running force the throttle valve open and see if the tension increases to keep it open if not the governor gear inside the engine failed don't hold it there long just long enough to feel it fight back
Aug 04, 2012 | Dewalt D55275 8 Hp Gas - Powered 17 -...
How to get more hp out of a honda 5.5hp engine
Your compressor was designed to produce 11.8 acfm at 90 psi turning neer max rpm (depending on pully combination between 800 ~1100 rpm ) with max pressure of 135psi. At 3600rpm the engine is producing max hp of 5 to 5.5. More power would not really produce more air without potentially destroying the compressor pump by over-reving. If your compressor is not functioning properly you will not get good air flow. Check instruction manual for time period to fill tank from empty. Could be 2 ~3 min. It is takes longer then problems. You can tell how your pump is doing by periodocally checking the length of time to fill tank. The next size range of gas compressor is about 8~9 hp with four cylinder pump and will deliver about 17 cfm.
Mar 15, 2011 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
I HAVE A TECUMSEH 10 HP ON AN AIR COMPRESSOR IT STARTS, BUILDS AIR PRESSURE THEN IT SHUTS OFF INSTEAD OF GOING TO LOW IDLE
try to decrease regulator, maybe you ask to much power and it shuts of. specially with cold motor its important to ask less pressure.
Jan 24, 2010 | Honda Jenny GT8HGB-8P2 8hp 8 Gallon GX...
Air Tools & Compressors Logo
466 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
