Question about Plumbing
Replaced pump and presssure vessel, water outside
Replaced pump and presssure vessel, water outside okay, very little water to house, ex husband is back flushing? He has been working on this 24 hours,
  • 474 Answers
If your like me your house has a pressure regulator to keep the pumps high cut out pressure from blowing your lines. Also a lot of domestic wells have a filter at the house to keep sediment out.
Posted on Sep 07, 2009
What is the minimum infeed pressure required for a RX500 as l have very low pressure. I ask because l live on acreage with tank water and fear my tank pump is not pumping enough pressure
General water pressure to most residential systems on Public water is going to be around 55psi. Pressure Reducing Valves are installed in most systems to regulate the pressure since the distribution lines on most public water systems exceed 100psi. A good pressure to have in your house will be in the range of 55 to 62psi. If you are using a tank for your water you can always install a pressure tank to increase the water pressure. This means you would have a feed line dumping water into the tank from a well or other source then a pump in the tank pushing water to a pressure vessel that will feed the house and will keep the home at a comfortable 55 to 62psi.
Dec 20, 2017 | Plumbing
Air conditional water drip
That happened to us. It was a broken pump, pump was up in attic. attached to our inside air-con unit. We had it fitted on an inside wall of the house, and so a pump must be installed to take away the condensed water to the outside of the house. Hindsight being 20/20 I would never buy one that needed a pump to get the condensed water out of the house. We would have put it an outside wall where the water goes straight outside, no pump needed. Our First pump lasted just over 2 years so warranty was expired. Cost us over NZ$500 to have new pump installed. Never again. Only attach your unit to an outside wall, even it looks prettier on the wall where it would need a pump. Bottom line:- Don't touch a pump. Pump was cheap but labor cost for serviceman astronomical! Bet of luck.
Apr 20, 2014 | Sanyo Split System Air Conditioner
Hi guys I have 2 grundfos cri10 vertical pumps (just for water pressure) I changed the expansion vessel which blew and I have primed the vent plug but for some reason every time I power the pump up it goes...
indicates no water supply for the pump
check tap from the tank is turned on
if the vertical ? pump is a submersible (in well type ) check for water in the bore/well
If a jet pump make sure that the whole jet system is primed -not just the pump and again make sure that there is water in the well/bore
Jan 10, 2018 | Grundfos Pumps Grundfos CRI 10 Stack Kit
Replaced diverter valve on worcester 9.24 combi and still only luke warm water
check your expansion vessel is not flat.if so recharge..simple way to check press in valve on vessel if water comes out or little air recharge..if water still in vessel the diaphram in vessel has split so replace vessel?hot water relys on expansion??
Dec 10, 2012 | Water Heaters
Have a ecotec 824 plus boiler the bar goes upto 2.7 and stays round 1.5 when not operating,what is causing this?
Sounds to me like the expansion vessel is not working correctly. When the boiler is on the water gets hot and expands into the expansion vessel but if the vessel is not working the pressure will rise and will eventually escape through the pressure relief valve.
Feb 18, 2012 | Computers & Internet
My worcester bosch 24i junior pressure keeps dropping if i have heating off for an hour i have to top up boiler and reset also when i have heating on the pressure jumps right up to over 4.0bar
When water is heated it expands. To deal with this all boilers are fitted with a small expansion vessel which is like a reservoir which holds the excess water.
This expansion vessel is like a balloon in a metal pot. When the water goes in the metal pot the baloon squashes a bit to make room for the extra volume of water. When it cools the balloon pushes the water back into the heating system.
What has happened is your expansion vessel no longer works. When the water heats up there is nowhere for it to go so the pressure jumps up to 4 bar. The Worcester boiler lets high pressure water escape (most boiler allow this to go through the safety valve at say 3.5 bar).
When the water cools the pressure drops very low as the volume of water contracts.
The problem is your expansion vessel - normally a little red painted metal cylinder inside the boiler.
Dec 22, 2010 | Bosch Water Heaters
Primed my shallow well pump---started okay--
sometimes pipe will scale over time depending on the water chemistry.
You can use PVC pipe indoors where your water enters the house.
May 06, 2009 | Flotec Corrosion Resistant Shallow Well...
Combi Boiler pressure gauge reading 0, and radiator half on!
The first thing you need to do is to put some more water into your heating system. This is usually done by allowing water from your (pressurised) domestic cold water supply to flow into the system: On older boilers, this is done with a connection (often made with a removable hose) on the pipework just outside the boiler. Newer boilers may have a built-in connection with some sort of removable link (sometimes looks like a plastic key).
Once you've got the boiler up to working pressure (typically about 1 bar - 15 psi), you should be able to bleed your upstairs radiator properly.
This may be all it takes, though the pressure excursions you're getting when you run the hot tap suggest there may be another problem. See what happens to the pressure as the boiler heats up and cools down. There really ought to be very little pressure difference between the two conditions. If you see significant changes, this usually means that the "pressure vessel" (or in hydraulic terms, system accumulaor) has lost its air charge.
The pressure vessel is a metal container inside the boiler, usually painted in red enamel. Somewhere near the top, you will find a schrader valve (like the one on a car tyre), and you can use this along with a tyre pump to replenish the air in the top of the vessel. This will reduce your pressure transients for a while, but you need to keep an eye on it. If the problem returns, you probably need to replace the pressure vessel (or clag another one into the plumbing alongside the boiler).
A.
Feb 03, 2009 | ACCO Brands Water Heaters
Plumbing Logo
79 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
