Question about Car Audio & Video
How can you make the splx subwoofers into 1 ohm
How can you make the sounstream splx subwoofers into 1 ohm its a dual voice coil
    Guru:
  • 1,326 Answers
Dual what??? the only way to do that is to have a dual 2ohm sub and run in parallel. pos to pos, neg to neg. Parallel cuts the ohms in half and series doubles it!
Posted on Sep 07, 2009
Don't know how to wire a kicker solo-baric L7 2 ohm dual voice coil 12 inch sub
Wire in series for 4R. +ve of coil to amp +ve. -ve of that coil to +ve of second coil and the -ve of the second coil goes to -ve of amp.
Aug 10, 2017 | Car Audio & Video
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How do wire my 15'' to 1ohm
If each voice coil is rated at 2-ohm, then wire it in "parallel". This will make a 1-ohm total load.
amp pos. out to coil 1 pos. to coil 2 pos.
amp neg. out to coil 1 neg. to coil 2 neg.
If the they are dual 4-ohm, the rating would be 2-ohm in parallel.
Mar 16, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
How do i wire mtx 9500 subs 2 10'' down to a one ohm
THE T9510-04 SUBS ARE SINGLE COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-04.pdf
THE T9510-44 SUBS ARE DUAL VOICE-COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-44.pdf
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 08, 2010 | MTX T9510-44 - 10" 9500 Thunder Series...
How do you hook up 2 15 inch cvr to 1 ohm
Hello juanelreypla,
If your CVR's have dual 2 ohm voice coils, they can only be wired for 0.5 ohm, 2 ohm, or 8 ohm final loads.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=3
If they have dual 4 ohm voice coils, they can be wired to a final load of 1 ohm. Wire the voice coils in parallel and then parallel both subs. Like the diagram in Wiring Option #1 shown here.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=4
Nov 10, 2009 | Kicker CVR12 Car Subwoofer
Logic soundlab cpx1400 need to wire to a kicker cvr 15
Hello discrete01,
The Kicker model number 07CVR122 has dual 2 ohm voice coils, and can be wired for either 1 ohm or 4 ohms. Model number 07CVR124 has dual 4 ohm voice coils and can be wired for either 2 ohms or 8 ohms.
Kicker's wiring page is here: http://www.kicker.com/dvc_wiring
If you have the version with 2 ohm voice coils, you want to use the 2nd diagram for a final load of 4 ohms to the amp. The 1 ohm load is too low for the amp and will cause it to overheat and possibly fail. If you have the 4 ohm version, use the wiring shown in the 3rd diagram which is a perfect match for the amp.
Hope this helps.
Aug 11, 2009 | Kicker CVR12 Car Subwoofer
I have 2 positives and 2 negatives on back of my alphasonik sub, do i connect amp to one side or both sides?
Hello gaz69,
Your PSW815 has 2 ohm dual voice coils allowing you to better match the impedance to your amp. Each voice coil is 2 ohms. If you wire them in parallel (both +'s together and both -'s together and then to the amp terminals), the sub presents a 1 ohm load which is too low for most amps. Wiring the voice coils in series (one + to the other - and the remaining + and - to the amp terminals) results in a 4 ohm load.
This link shows the wiring diagram for both options. If you know for sure that your amp is 1 ohm stable, use Wiring Option #1. If the amp is not 1 ohm stable, use Wiring Option #2.
Hope this helps.
Aug 09, 2009 | Alphasonik PSW815 Car Subwoofer
How to wire it up
your best bet is to go onto www.the12volt.com and find the tab at the top that says subwoofer wiring diagrams. Next go to google and search for audiovox subwoofers and search through. You will definately have no issue if you find the model it will tell you the impedence of the subwoofer. 2 ohm dual voice coil, 4 ohm dual voice coil, 8 ohm dual voice coil. anyway it is a dual voice coil
Jun 13, 2009 | Audiovox Car Audio & Video
Wiring 12" icmb-5612 preformance teknique subwoofer
That sub has dual 4-ohm voice coils. It can be wired either as 2-ohm, 4-ohm, or as 8-ohm.
2-ohm = voice coils in parallel (both positives and both negatives connected to your speaker amp out wires).
4-ohm = use only 1 voice coil (either is OK).
8-ohm = voice coils in series (connect the positive of one voice coil to the negative of the other and connect the remaining positive and negative to your speaker amp out wires).
Mar 24, 2009 | Performance Teknique ICBM-5612 Car...
Car Audio & Video Logo
108 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
