Question about DeLonghi EO1238 Toaster Oven with Convection Cooking
Toaster overn stopped lighting/heating
I have the exact problem described by so many others on this site w/ my Delonghi EO1238 not heating nor light coming on. Was working fine, then next time I went to use it, there was nothing. Time still works, but nothing else!
  • bdlodahl Sep 11, 2009
    I will see if this works - thanks for the suggestion!
    President:
  • 1,714 Answers
They really don't make these to be able to repair....but, if you want to open it up there will be a 'thermal fuse' that has blown. More than likely you can go to Radio Shack and find one to replace it. It doesn't have to be the same 'temperature rating' but try for close as possible. Here is a photo of one;
toaster overn stopped lighting/heating - b36a221.jpg
Posted on Sep 06, 2009
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Bottom elements on DeLonghi AD699 failed.
Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
BOTTOM ELEMENT DOES NOT WORK
If the top element is working, then it is either the element, the wiring harness , or the control board.
Since both elements are controlled through the same temperature probe, then the temp. probe should be OK.
The heating element must be removed and tested using a multimeter.
The part is tested disconnecting wiring from element contacts, setting a multimeter to read impedance at Rx1, and reading Ohms on element contact.
If the circuit is open (no continuity and infinite Ohms value), then the element has blown and must be replaced.
If the element has continuity, test the wiring harness, then replace wiring harness or control board.
All the test must be done by a trained repairer, strictly observing all health and safety rules.
Regards.
Oct 21, 2009 | DeLonghi EO1238 Toaster Oven with...
Door spring broken
Hi Eli - here is the link to the delonghi service centers, perhaps you can call them and ask then where to hook the spring
http://www.delonghiusa.com/index.php?service
Jun 02, 2009 | DeLonghi EO1238 Toaster Oven with...
Oven just stopped working
1-usually it easy proplem
2- check your electricity voltage by testsrowdriver or another good device like radiocasset or voltmeter if you can
May 31, 2009 | DeLonghi XR450 Retro Toaster Oven with...
Dead Delonghi toaster oven
Your timer switch burned out. The timer is manual and will tick even unplugged. Delonghi switches are available at The Gourmet Depot website or search "small appliance parts" for other places that sell the switches.
Mar 23, 2009 | DeLonghi EO1258 - Stainless Steel Toaster...
No power.
There is usually a thermal fuse in line with the power wire. Check for one inside a teflon mesh wire in line with the power. Inside of the toaster over of course.
Sep 07, 2008 | DeLonghi EO1238 Toaster Oven with...
Removing face of DeLonghi AR1070
This is a two slice Delonghi toaster, model CT12 and is has stopped heating on the right side
Jun 14, 2008 | DeLonghi AR1070 Retro 1500 Watts Toaster...
Spring in door
I have the same problem. The end broke off. I heated the end with a torch and bent a new loop (cooled it in cold water). I hope it will work for a while. I could find a replacement on the internet. To get to the spring, just remove the left side panel (3 screws)
Jan 06, 2008 | DeLonghi EO1238 Toaster Oven with...
Light and oven does not turn on.
:-) Same here, in the middle of cooking the toaster just died. O' well, i am a tech! i opened the unit and diagnosed the problem. the unit has a non-resettable high limit thermostat that blows open when reaching high temperature. the problem is that when it happened, the oven wasn't even hot and was only on for a bout five (5) minutes. From my experience, it is due to a design defect. from all i have seen so far, it doesn't seem that the company cares about its reputation or customers... what can you expect from the French?!
Oct 29, 2007 | DeLonghi EO1238 Toaster Oven with...
DeLonghi EO1238 Toaster Oven with Convection Cooking Logo
134 people viewed this question
Top DeLonghi Toaster Ovens Experts
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
