Question about Lakewood HV-18 Floor / Box Fan
Fan shows that the power is on, but fan not running
Dust is evil to all mechanisms!! Keeep UNPLUGGED..then Vacuum all accumulated lint in fan motor assembly, and soak with WD-40...I just did detailed dust cleaning with toothbrush....Fan now runs awesome!! Good Luck
Posted on Sep 06, 2010
Luxpro psd111 thermostat shows snowflake (sometimes blinks), outdoor fan works, but no cool air comes out inside- no air flow at all. Is it the thermostat or an a/c unit malfunction?
If the outdoor unit is running the indoor fan should definitely be running. Turn power off to indoor unit. Put red green and yellow wires together behind the tstat with a wire nut. That is power (red), indoor fan (green), and compressor (yellow.) Turn power back on. This is bypassing the tstat and you should have indoor fan and outside running as well. If yes the problem is in the tstat, if no indoor fan the problem is in the unit. Good Luck!! Let me know!!
Apr 28, 2017 | Heating & Cooling
Could you show me the correct way how to power up the hard drive box a green circular light is by the power cord is on when plug up but the fan is not running could you show me what is wrong the computer...
Could you take a picture of the entire back of the PC? You only show the power supply connected with power, what about the graphics card output? and power to your monitor etc.?
Oct 19, 2013 | Computers & Internet
The output(w) is indicating o.oo and it's indicator light is red .I only have a couple of floor model fans plugged. Should it be showing something and should the light be green?
inverters run on a square voltage unlike normal 110 runs on a round voltage, the only 2 things that won't run on the inverter is fans and electric blankets
Jul 22, 2011 | Cobra 2500w Power Inverter
I have a 2007 Vulcan 1600 classic and the cooling fan won't run. any ideas on what to test and how to test it? Jim
This fan runs of a heat sensor..The sensor may be gon......Trace the wires and see if their is power from the sensor when it gets worm and also powet to the sensor........Power to the sensor is good but power not showing from the sensor after temp light or gauge shows time to cool means the sensor is unservicable..Hope this helps.
Aug 16, 2010 | kawasaki VN 1500 Vulcan Classic...
When i power on fans run but computer doesnt boot gateway 510
please remove your RAM and clean it with a white cloth and reinsert the RAM and check it
May 19, 2010 | Gateway 510 X (10272197) PC Desktop
My evaporator fan is not working even though I have power to the fan from the harness. The fan works when tested running power straight to it on the bench, and the leads have continuity to the fan motor,...
Good day,
One possibility is the door has a fan switch on it, and would not run if the door was open, or the switch was bad. Some models had a switch in the freezer on the top or side of the housing where the door mates to it.
As well some had 2 fan switches. The one described as well as an other one in the food compartment as well.
In either door, the switch may be a combination switch with 4 wires connected to it. 2 for the light, 2 for the fan.
In addition, many Amana's had the power to the fan routed thru the defrost thermostat. It's a round disk clipped to the top of the coil with 2 wires coming out of it. It's about 1" in diameter.
The purpose of wiring it that way, was so the fan wouldn't start running after a defrost cycle until the coil reached 20 degrees or colder.
Feb 01, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
Cooling fans are not running 2001 mitsubishi
Check if your fuse is blown! If not have the wires tested that run into your fan if there ok and show power then your fan needs replaced! Please give me a thumbs up if this helped! Thanks
Sep 24, 2009 | 2003 Mitsubishi Galant
CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Jun 20, 2009 | Dell OptiPlex GX520 PC Desktop
Programmable A/C thermostat has power but shows no temp.
Check power totast. Float switch sometomes kills power to stat. Check drain.
Jun 08, 2009 | Heating & Cooling
Concise Question, Poweredge 1800 powerup failure
It is definitely the PSU that's not working properly,because defective motherboard should still receive the 12V. you can use a desktop standard power supply to check if the server runs fine, even a cheap one is ok for a test run. they sell also cheap (about 15-20$) PSU tester, definitely worth when working with servers and WS.
the Power supply fan might have a dedicated rail coming from the thermal sensor(thermistor.)this is why it can run even with bad 12V rail.
Feb 11, 2009 | Dell PowerEdge 1800 Server
Lakewood HV-18 Floor / Box Fan Logo
175 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
