Question about Sub-Zero 561 / F
Refergerator side back panel freezing up with ice
I am having a problem with my subzero, on the refrigerator side the back panel is freezing up with ice. When the ice melts and water leaks on the floor. What is causing the ice on the backside panel and how do I fix it?
  • 71 Answers
2 posibles problems. if the ice is only about 4 an 8 inches you have a seal system problem.(evaporator freon leak) need replace the evaporator asap. if the ice cove a big part of the back wall you have a thermostat problem. for replace the evaporator better call a tech. remember to call a subzero factory authorized company. maybe still under some warrantty> good luck LEAVE YOUR COMMENT IF IT WAS GOOD FOR YOU....... THANKS
Posted on Apr 02, 2010
    Director Badge:
    Uploaded 100 video answers.
  • Sub-Zero Master
  • 488 Answers
Most likely refrigerator section is low on freon. Somewhere leak in sealed system in 90% of cases its evaporator coils(they always sweating, always wet). Sealed system has warranty 6 years parts and labor and 11 years on parts only. Try to call subzero direct first, by serial # they can tell You what is under warranty, its very expensive repair. Hope this helps. How To Replace Evaporator On SubZero Refrigerator 500 series HD 1080
Posted on Jan 24, 2015
Hi, I have subzero side by side refrigetor. Building up on back panel on refrigetor side . I defrost it clean and in week again ice building up ? Ho to resolve ? Thanks
check aall your seals on your doors and make sure they are sealing tight. Your compressor is working extra hard and freezing up. Also check the thermostat and make sure its not turned down to low, that will also cause compressor to run hard
Oct 09, 2015 | Refrigerators
Subzero 632 error code 37
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Jul 31, 2008 | Sub-Zero Refrigerators
Sub-Zero 590
Ignore the fan operation... That is perfect.
You are likely experiencing a DEFROST failure
(most commonly a defrost timer failure)...
part number 3081180 item 69 on your exploded
top view (top right side as viewed from the front).
There are typically only three (3) elements to a DEFROST
circuit:
- Defrost Timer (as noted above)
- Heater element to WARM the EVAPORATOR
- DEFROST thermostat... inhibit excess heat
(closed circuit at freezing - Opens at room temperature)
Check your defrost pan...
there should be water there DAILY...
IF not: you are assured that your DEFROST fails.
Per YOUR DESCRIPTION...
You need to look for a SUDDEN REASON (huge air leak)
why FROST would form so quickly...
USUALLY a big pizza box... BUT ANYTHING blocking a
TIGHT DOOR SEAL will cause massive frosting.
It is taking moisture from the WARM ROOM AIR and blocking your evaporator...
Yes ... all INTERIOR panels must be in place for the refrigerator to function properly.
guaranteedparts.com http://www.guaranteedparts.com/picture_library/Subzero/Subzero-500%20Series/590.pdf
Sears
http://www.searspartsdirect.com/refrigerator-repair/symptom/REF0003.html
Carnac the Magnificent
Apr 06, 2017 | Sub-Zero 690 Side by Side Refrigerator
Ice keeps forming inside on the back panel of mysubzero model 550
If the ice is on the back panel especially a block of ice in the middle left part of your panel, then you have a sealed system problem. Check to make sure that your condensor coils above the refer are clean, and if it continues to have an ice block then you have to have a technician come out an do a major repair. This is not something you can do yourself, most subzeros have a 6 to 12 year sealed system warrantee that covers either all of the repair or just parts. This is an expensive repair if it is not warranteed, but when the refers cost 8000 to 10000 new it is usually well worth it. Most often it is the result of a slowly leaking evaporator, though most inexperienced technicians replace the compressor first, so make sure you use an experienced Sub-Zero technician. Good Luck, Appliance Specialits
Nov 12, 2009 | Sub-Zero Bottom Freezer Refrigerator
Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Oct 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
Oct 03, 2009 | Sub-Zero 632 / S
ICE IS FORMONG ON THE BACK WALL OF A SIDE BY SIDE SUB ZERO REFIGERATOR.
This is typically a problem with the sealed system (refrigerant leak). Usually a circular patch of ice or water driplets half way down on the back wall. The solution involves replacing the evaporator coil. Subzero will give partial warranty up to 12 years.Full warranty for 5.A subzero authorized company is recomended.
Sep 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice forming in the back panel of the subbzero refrigerator
The door seals are leaking. They are allowing moisture in and it is freezing.
Sep 09, 2009 | Refrigerators
SubZero 690: Frost builds up on ice chute flapper door
you have a bad seal, Take a dollar bill and slide it in between the door seal and the frig. slide it up and down to see if if has drag on it. If you find places it dont touch loosen the screws and adjust the hinges till it fits tight. In some cases you might have to tweak the doors if they need it.
Aug 11, 2009 | Sub-Zero 690 Side by Side Refrigerator
Side by sise refrid freezer top is not cooloing on freezer side warm on refergerator side
suspect fan is not working - can you hear fan?
if not, chances are fan is jammed with ice build up. take back panel off inside freezer and if there is ice build up, melt off with a hairdryer. also check for continuity thro fan and make sure it rotates freely
Oct 09, 2008 | Whirlpool Refrigerators
Refrigerators Logo
484 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
