Question about Canon PowerShot A95 Digital Camera
A95 Trouble My camera will not turn on. If i press the on/off button the little green light goes on, the lens starts to extend out, then a beeping noise sounds and it shuts off. On the screen, its black and a tiny code is displayed on the bottom that says "E18"
  • Canon Master
  • 4,738 Answers
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Posted on Dec 11, 2007
Camera shuts off even with new batteries
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 12, 2010 | Canon PowerShot A95 Digital Camera
Camera starts, but shuts off immediately afterwards
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 01, 2009 | Canon PowerShot A95 Digital Camera
My Polaroid camera i631 won't turn on!!
Here is the solution for your problem. If you look at your camera at an angle, you will see the zoom lens is little bent to the side. I want you to put press on it to snap-it into it's place. After you heard a click, then turn-on your camera. This will fix your cam.
Vicent
Apr 04, 2009 | Polaroid i631 Digital Camera
Error code E18
Lens errors (aka E18 errors for Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Dec 20, 2008 | Canon PowerShot A95 Digital Camera
E18 on Canon Powershot A95
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
take a look at e18error.com website for more info
Jul 30, 2008 | Canon PowerShot A95 Digital Camera
HELP
This happened to me once. SOMETIMES you can correct this yourself. The lens must be extending from the camera at EXACTLY 90 degrees if the lens is crooked, then straighten it, gently! If you succeed, the lens may retract as it is supposed to. You could also futher damage it with this procedure, so THINK ABOUT IT FIRST.
Mar 08, 2008 | Polaroid i733LP Digital Camera
Digimax l60
I don't know, it's not powering up......
Jan 03, 2008 | Samsung Digimax L60 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
CAMERS TURNS ON LENS OUT THEN BACK IN... 3 STEADY CLICKING SOUNDS
well i´m the bad news guy, it could be two things, or u droped the camera and the zoom lens is out of the place and the sensors arent working properly or it´s just the sensors that are no working, the only way is to send to a repair centre normally they just replace all the lens. All the beeps it´s just to say that the lens is lost.... can´t locate it self.
Feb 04, 2007 | Canon PowerShot A95 Digital Camera
Camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Jan 08, 2007 | Samsung Digimax S500 Digital Camera
Canon PowerShot A95 Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
