Question about Moen & One Handle Tub & Shower Faucet
Moen one handle tub & shower is leaking from spigit
How do i remove the cartridge ? is the stem part of the cartridge i have removed brass retaining ring.
  • 129 Answers
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Posted on Sep 29, 2009
How do you remove a cartiarigde from moen shower body (single handle)
There is a special tool that yo can use to remove an old and stuck moen cartridge and they can found at your hardware store. Now before you remove the cartridge be sure to remove a small brass or copper pin located at the top of the stem. you will see a groove in the stem cover where the pin is located. once the pin is removed hookup the puller and remove stem. sometime you are able just to grab the stem with a pair of pliers and give a good pull and twist to get it out. don't pull to hard to damage the plumbing in the wall. good luck and I hope I was able to help. As always, TURN OFF THE WATER FIRST...
Feb 11, 2011 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower faucet can't get cylinder out
New moen cartridges for tub/showers come with a handy white plastic tool to aid in old cartridge removal. One end is squared off for a wrench, the other is slotted to place over the old cartridge in the wall after the clip has been removed. Place onto cartridge and use a wrench to turn several times back and forth. Remove , grab the stem with pliers and give a tug. You want either service part #1225B (pull/push to turn on) or #1222 (just turn knob counterclockwise to turn on. Get the replacement before you proceed.
May 06, 2010 | Moen & Bayhill& Single Handle Tub & Shower...
How to remove diverter cartridge in shower 1 handle
Follow these steps.
  1. Remove Set Screw in handle and remove handle.
  2. Remove the 2 screws from the handle housing and remove the housing and escutcheon from escutcheon adapter plate.
  3. Remove valve stem screw and valve stem coupling.
  4. Remove the escutcheon adapter screws and escutcheon adapter.
  5. Using a pair of pliers pull the cartridge retaining clip out of the valve.
  6. Grasp the cartridge by the stem and pull out.
I hope this is helpful to you, please rate if this answer was of any help. Good Luck and have a great weekend.
Apr 02, 2010 | Moen & One Handle Tub & Shower Faucet
Moen single stem bathroom basin tap (25 years old). Trying to remove cartridge to grease it or replace it. Have removed handle and retaining clip. Pulled hard but can't shift it. Don't want to break...
You are on the right track. You have to use some force when pulling the stem from the faucet. Your replacement cartridge should have a little black or whit cap. that is inserted on top of the cartridge and by turning the cap will help loosen the whole cartridge
Feb 21, 2010 | Moen & One Handle Tub & Shower Faucet
Removal or moen shower cartridge - plastic tab seems to be keeping the cartidge from being removed -- only get cold water, no hot
Once you have removed the U shaped cotter pin whis is brass in colour. Use a pair of plyers and hold on to the brass stem. you will need to pull fairly hard to remove. If you have the white or black stem loosening knob which comes with the replacement cartridge you can insert that into the brass cartridge where the plastic sides of the cartridge are showing. Turn your plastic konb clockwise to loosen the cartridge and then pull out.
Feb 13, 2010 | Moen & One Handle Tub & Shower Faucet
I have a Moen shower knob that broke...
You are not the first. Usually you must break the plastic handle to remove it and then you can access the screw and have leverage to hold the brass stem with pliers while you try removing the screw. Caution, do not try to bend the handle to break it off or you will break the brass facet stem. Also, there are two styles of handles: one has a short innercone,the other has a longer inner cone. You need to know this before you purchase a replacement. Goodluck< Macgivor
Dec 27, 2009 | Moen & One Handle Tub & Shower Faucet
I have a Moen shower tub single handle from the
I took the parts to the Menards in town. Luckily I found the guy that knows it all! He showed me the rubber gasket( that holds the ball) to purchase as well as recommended that the 2 small rubber gaskets that were in there to be replaced as well while I had it open to avoid doing this in the future. I got home and replaced them and no leaks:) Thanks:)
Aug 28, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Removing a moen cartridge
Remove the retaining clip and then take a pair of plier or channel locks to grab the stem and work that stem side to side gently as you pull up or out.
Apr 07, 2009 | Moen & One Handle Tub & Shower Faucet
Moen positemp cartridge won't come out of brass body housing
If the clip has been removed it will come out. these things get incredibly tough to remove. Moen does sell a little puller just for these. I have used a socket with the screw in the stem to act as a puller.
If you have the water off AND your sure your have the correct new cartridge you can give the valve a little heat to help soften things up a touch. Use a heat gun with caution
Please rate this response and good luck, Phil
Dec 28, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Moen & One Handle Tub & Shower Faucet  Logo
583 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
