Question about Garden
Poulan Pro gas weedeater surges and dies
Poulan Pro gas weedeater surges at a steady throttle setting when held in a normal upright position (trimmer head parallel to the ground). Unit dies when turned on its side for edging.
I know it's either fuel or carburetion, but can anyone get me a more specific answer?
2 Suggested Answers
  • 246 Answers
SOURCE: Poulan 17'' Gas Weedeater keeps dying!
Hello su2yak2:
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
Poulan pro brushcutter ppb150e is starting but cutting off after a few minutes, why is this?
FAQ Trimmers ' Poulan Pro
www.poulanpro.com > Customer Support > FAQ
If the unit has an on/off switch, move it to the on position (usually indicated by the ... This should happen between 1-6 pulls, but no more than 6 pulls. 7. ... Some units use a carburetor which does not require holding the throttle trigger. ... If you smell fuel after following the starting procedure, assume the engine is flooded.
Poulan Pro Trimmer dies when I give it gas.? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 22, 2007 - If you remove the two springs holding that cover on the muffler off you can ... Put it all back together and you should be able to crank up and cut. ... Poulantimmer PPB 100 JUNK, since new hard to start cannot keep running ... If, it sit with fuel in the carb then it may still need cleaned with some Carb Spray.
[PDF]OM, PPB150E, 2007-01, TRIMMERS/EDGERS - Poulan
Nov 25, 2015 | Poulan Garden
Spark plug gap for poulan weedeater
Go to the following site where you may well find parts needed
http://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/poulan/hedge-trimmers/pp2822-966513101-2011-03/engine
Jun 10, 2014 | Poulan Pro Ppb330 33cc Gas Line Grass Lawn...
What is gas mixture for weedeater poulan pro 25cc 17" cut
40:1 ratio is the manufature spec for 2 stroke units. unless it is a four stroke then there is no mixture just a good quality gas.
Jun 03, 2014 | Poulan WeedEater Hedge Trimmer 25cc Engine
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Out the box.Cranks and runs on cold.when you give it full throttle and knock it off fast idel try to let it idel it die's.After u use it a few min. it die's and want start back till it cools.
This is a common problem out of the box for weedeater products. This simply needs a carb adjustment which is not something the consumer can do (requires a special tool), You will need to take this to a weedeater dealer near you to get it done, it's covered under the warranty.
Jul 21, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan pro weedeater will not start without starting fluid and wont accelerate after starting Once started the first time it is easy to restart and idles fine, just cant accelerate the motor without it...
Your carburator is clogged.
1st make sure you have FRESH gas.
Empty and clean the fuel tank
Remove and disassemble the carburator and soak it in fresh gas for about 15 minutes to disolve any gunk.
Using a can of small carburator cleaner ( available at Lowes, Home Depot etc.) blow out all the ports.
reassemble and refuel with clean fresh gas
The little carbs clog easily
May 19, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
ENGINE STARS AND THEN DIES
Try changing the fuel filter and if that dont do it there is a small screen inside the carb that usually plugs up carefully disassemble it and clean it out with a good brand of carb cleaner
Jul 20, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Garden Logo
340 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
