Question about Mitsubishi HD4000U Multimedia Projector
Problems with keeping the projector on!!
I turn on my home theater and everything turns own including the projector. However, 3-5 minutes later the projector turns off. The sound and everything else stays on. Finally, the status light blinks constantly.
Any tips
  • 682 Answers
If it is blanking orange:1- if any objects are blocking the air inlet or outlet grille remove them.2- do not expose the air outlet to hot air emitted from heating appliance.3-check whether the filter is clogged with dirt-clean the filter if clogged.
if it is blanking green:-after status indicator stop blanking press power.if you unplug power cord while the fan is rotating the lamp may be not turn on for one minute next time you plug the cord.
press power button several times.
Posted on Mar 17, 2008
Tell me please the projector, for home viewing ?
If you want to turn your room into a real cinema, a home theater projector is what you need. We have reviewed 5 best home theater projectors for you, so you can choose the one you like the most.
Apr 06, 2017 | The Office Equipment & Supplies
Theatre projector is unable to switch inputs in menu
This is worth a try: Turn everything OFF. Unplug all the inputs from the projector and turn them off too. Next, turn the projector ON and all the input devices ON. Then, one by one plug each input device (already turned ON) into the projector. See if this helps. I have a SONY monitor that supports multiple inputs and a few times this has worked.
Good luck.
Jan 28, 2015 | Sanyo PLV-WF20 LCD Projector
- Check LED Status
a. Lamp LED Light
- Check Lamp
- Check Lamp Driver
- Check Main Board
b. Temp LED Light
- Check Thermal Sensor
- Check Thermal Switch
- Check Fan
c. Color Wheel
- Check Color Wheel
- Check Photo Sensor
Sep 03, 2014 | Optoma Hd70 Dlp Hd High Definition 720p...
I have an optoma tx1080p projector and Yamaha receiver. Recently we started getting the problem where the projector keeps saying that the source is not found. When I connect the hdmi cable directly to the...
This is most likely a problem with what's called "HDMI handshake." It's a silly protection scheme called HDCP that is meant to keep people from copying content. The best thing to do is unplug everything, then turn on things in this order: receiver>projector>sources (directv, Bluray). If that does not work, check for firmware updates for the receiver or projector.
Oct 29, 2013 | Audio Players & Recorders
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Nov 27, 2008 | Samsung HT-Z310T Theater System
Check the cooling fan/ air ducts - sounds like it's overheating and shutting off to prevent damage.
Mar 12, 2008 | Computers & Internet
XG-C50 Problem
Replace the fly-eye lens of projector.
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Open Questions:
See all Mitsubishi HD4000U Multimedia Projector Questions
Mitsubishi HD4000U Multimedia Projector Logo
399 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
