Question about Insignia Digital-to-Analog Converter for Analog TVs
No sound on sony tv
I just hooked up convertor box to my sony tv. able to get channels and clear pictures, but no sound. i have the volume up on tv and down on convertor box. tried to then increase convertor box volume but nothing.
  • Insignia Master
  • 5,568 Answers
Your set may have a choice of audio sources and outputs in the basic (initial) setup since it is not uncommon to mute the internal speakers and get your sound from a home theatre system or receiver. Also, if you are using S-video connectors between converter and set, there is no sound path, this is video only, and you will have to add a couple of cables, likely with RCA connectors, between the two.
For reference: Audio cables: Red=right channel, White=left.
Posted on Sep 06, 2009
No picture, but sound
tried to hooked up with an air antenna. if you can not get any channel and just a white raster or snow, it could be the tuner get fried.
Jul 22, 2012 | Sony KV-32S45 32" TV
We just got a new cable box and now the Picture works but no sound. The volume is not muted on the tv or cable box. We've tried connecting the cable box three different ways and still get the same...
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
Sep 08, 2011 | Sony KDE-50XS955 50 in. Plasma HDTV
I have a Quasar TV that has worked perfectly fine until the other day. Picture is fine, but no sound. The speaker volume is on.
Check all your channels. If you are getting sound on some channels but not others it is a good possibility that your SAP setting is turned on. Simply go into your audio menu and disable the SAP. Not sure about your model tv but some Tv sets had a switch on the back to disable the speakers and some have a setting in the menu to disable the speakers. If you have a digital cable box hooked to the tv it is possible the cable box volume is turned all the way down which will override your tv volume. Check these options and hopefully one of them works for you.
Jul 10, 2010 | Quasar SP-3235 32" TV
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Tv + converter box = no sound
Try these steps: Turn the volume on your converter box all the way down. Turn the volume on your TV up to ½ way. Now turn up the volume on your converter box until it is at a comfortable level. More information at http://www.ezdigitaltv.com/index.html
Mar 31, 2009 | Sansui CDVD1310 13" TV/DVD
I recently hooked up my dtv box, tuned the antenna and have a great picture. On every channel I have background noise. Sounds like bacon frying, hissing noise. I also set up someone else's tv, very simple....
If there is a volume control on the remote that came with the converter box, use it to make sure the box volume is set to its maximum. Many models allow you to control the volume out from the box to the TV, and the levels are set about halfway. When you turn up the volume on the TV cause it's too low, you can get the kind of audio problem you describe. Make sure you turn the volume down on the TV first before starting with the box.
Feb 18, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Aug 17, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital-to-Analog Converter for Analog TVs Logo
376 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
