Question about Maytag Washing Machines
Agitator will not function,everything else works including spin cycle
  • 2,200 Answers
Hi
The part where the agitator attaches to the transmission shaft can become worn, and strip out inside the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly.
If this happens, you need to change the dog kit inside the agitator. Remove the bolt holding the agitator in and lift it off the shaft. The agitator should pull apart and then you will see the dog kit inside.
You can check here by entering your specific model number to see what the kit looks like.
http://www.repairclinic.com/Maytag-Washing-Machine-Parts?s=b4a11c201
Hope this helps. Please do rate this answer. Many Thanks.
Posted on Sep 06, 2009
Washer makes clicking sound while agitating
you should replace the control panel or get a new washer.
Mar 01, 2014 | Whirlpool Washing Machines
My 10+ yrs old Frigidaire gallery # GLTF1240AS front-loader drum won't agitate/spin
Check and see if the drive belt broke? On mechanical agitators using gears, a solenoid may fail and drive motor won't function.
Dec 23, 2013 | Frigidaire Washing Machines
Have a circa 1999 Kenmore Three-speed clothes washer (Top Loader) that keeps on agitating regardless of the cycle I put it in. Some cycles do nothing at all, but others (such as Rinse) make it just keep...
The clutch assembly works only to release the basket allowing it to spin during the drain and spin cycles. The drain function works only when the spin function works. If the machine also agitates during spin cycles, then the problem is in the transmission assembly not able to release the agitate gear from the agitate spline in the drive shaft.
Sep 30, 2010 | Kenmore Washing Machines
Agitator stops while in spin cycle
Assuming that this is a basic Whirlpool top load, direct drive, neutral drain washer, the agitator is supposed to stop during the spin cycle.
Please see the following Whirlpool installation and service manual for top load machines.
If you look at the description of how the transmission works, there is an "Agitate Cam" that lifts the "Agitate Gear" out of contact with the main "Agitate Rack" when the machine goes into spin mode
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I have found though that because of the friction between the agitate gear and main drive shaft, including the oil itself, the agitator may move while in spin mode.
Oct 14, 2009 | Whirlpool Washing Machines
Spin cycle is not working right,
This is a problem in your transmission. Not Good!
May 18, 2009 | Washing Machines
GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Roper RAL6245AW0 Washer Won't Drain or Spin
We have a Kelvinator Washing Machine that just won't drain , but fills , agitates , & spins just fine. What shall we do?
Oct 13, 2008 | Washing Machines
Spin cycle with agitation motion occurring simultaneously
Hi again,
Appreciate the "Ask Me".
I believe the dampness is due to slow spin speed as you also have concluded. And I suspect that partial winding of the motor is the culprit. Hence, replacement is in order.
As to your concern why the agitator also operate during the spin setting, it could possibly be stuck or locked agitator dogs. Agitator dogs function is better explained here by another FixYa member, jsrock516.
Cheers.
Jul 25, 2008 | Washing Machines
Everything works but machine won't agitate
The pull at the bottom of transmission should turn both ways.. one way for spin the other way for agitate... if transmission turns both ways means not locked up and probley bad motor..
Jan 06, 2007 | Amana LWA40A
Washing Machines Logo
54 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
