Question about Kitchen Appliances - Others
Temp.degree #s worn off controller button - Kitchen Appliances - Others
  • duukey Sep 06, 2009
    yes but i was trying to find where to buy new controller
    President:
  • 497 Answers
Im not sure what your asking, but if you cant read the numbers, i suggest you replace the gauge.
Posted on Sep 06, 2009
Unit acts like a ghost has taken over the controls. Sleep timer frequently flashes rapidly on and then off many times within a few seconds .... beeping loudly each time. Also, the desired temp eventually...
Sometimes the button boards will get worn or malfunction. Nearby lightning strikes make electronics flaky sometimes. But start with the button board. www.searspartsdirect.com
Sep 26, 2013 | Frigidaire 6500-BTU Window Room Air...
The inside control display on my Aqualink RS4 is red instead of green on the filter pump button. What does this mean?
either the temp is below 38 degrees if so it is in freeze protect if not 38 degrees or lower bad temp sensor go to system set up and go to program go to freeze protect and un check the filter pump
Feb 16, 2013 | Jandy Aqualink Rs4 One Touch Control...
What's an f1 and f2 code mean???
The F1 code means that a button on the touchpad is stuck
The F2 means that the oven tempature was at least 100 degrees over what the temp it was set to was
the F1 will come sometimes if the ribbon connection on the touchpad doesnt fit well into the control board and other times it comes because the touchpad is defective
the F2 comes up because the control has measures the temp and thinks that when it set as lets say fro instiance 350 degrees the control thinks the temp ahs reached 450 degrees(100 plus over) typically the thing wrong when the F2 comes up is the oven sensor at room temp to be between 1060-1100 ohms
However if you are getting both error codes at the same time the only thing common to both is the oven control and if both at the same time i suspect the control is the problem
GENE
Sep 06, 2011 | Whirlpool Kitchen Ranges
How do you set the temperature to display in degrees F instead of degrees C? This on the Heater/AC control.
SM Santa Fe:
Default Fahrenheit
  1. Hold the AMB button and press the TEMP down button for at least 3 seconds.
Apr 09, 2011 | 2002 Hyundai Santa Fe
Not cooling... cleaned the rear grill, temp at 80 degrees. when press the thermostat button to lower the temp, nothing happens
IF BUTTONS DONT RESPOND THEN YOU HAVE TO REPLACE THE CONTROL BOARD SENTRY III
CONTACT THE MANUFACTURER TO OBTAIN REPLACEMENT BOARD 858-566-7473
Sep 08, 2010 | Breezaire WKL 4000 Wine Cooler
Heater reads spa water 15 degrees higher than it is
if a 3 wire system put pool at temp desired and spa at 104 if 2 wire to firemans switch run heater all the way up to 104 the system will control the temp
Feb 22, 2010 | Jandy AquaLink RS2/6 All Button Dual...
Oven cooks 10 degrees cooler. How can I fix it?
select bake
set the oven to 550 degres
hold the bake button until you see the temp go to zero
push the temp select up until it changes in five degree increments to the desired bump up in temp you can raise it or lower it up or down by 35 degrees in five degree increments, once you have the desired adjustment it will revert back to normal on the controls screen readout
check the oven temp and adjust as necessary, this info is available in your users manual as well.
Jul 14, 2009 | Maytag MER5775Q Electric Kitchen Range
When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
http://hottub.synthasite.com
May 24, 2009 | Balboa Instruments Duplex Digital Panel 2...
Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
May 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Appliances - Others Logo
22 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
