Hi. see i power the tv. tv comes on. if i pick antena 1 or aux. i see no raster or snow in picture. if i uce the cable i see no picture at all. i you push the remote control you can see the menu. if i do autoprogram. the tv looks like is doin it you see the number pass. but there is no viveo in any input component or tuner or video 1,2,3 or wherever. i never have this problem i dont have a service manual. all volts in power suply are ok. there some regulators in signal br they ok. i don got it. help me if you can. thanks.
  • 835 Answers
Ill start by linking you to websites where you might be able to find your maunal to your tv for free.
http://tv.manualsonline.com/manuals/
and
http://www.retrevo.com/samples/index.html
Let me clarify what your seeing. If the tv is on the antena 1, or aux, then you see a picture and get sound ect, and its clear.. If you switch to the cable channel or any other channel you don't get any picture at all.
If the tv is from the cable that runs from the wall and is screwed right into the back of your tv, then your only going to get channels from the tv antenna channel. and it working correctly.
The video 1-3 is for the input jacks either on the front or the back of yout tv. They are normaly the yellow, white, and red input plugs you see.
Im not sure what your saying about the cable.. Is tht a channel or you talking about turning on the cable box?
If your talking about turning on the cable box, try this, Run the cable from the wall, right into the back of the cable box into the input... Then from the output of the cable box, run that into the input of your tv. You can either use the codex cable, or the RCA wires (the yellow, red, white) ones. Depending on what you use the input channel, (video 1-3) or the attena channels 1- what ever your tv goes to. it should now show up.
hopefuly I understood what your asking, and what I have said has helped. If not please just post an other comment, and tell me more in detail what your current setup is and maybe I can help. Along with what type of tv you have.
Posted on Oct 09, 2009
Toshiba 24" led tv mo. 24ps1e VGA is ok raster snow is ok ,after connection of cable only chroma picture seen,no Y signal.
Try to reset it to the factory settings and Them remove the power cable for atleast 5 minutes but Will be better to power OFF for 12 hours
Jul 18, 2013 | Televison & Video
No picture, but sound
tried to hooked up with an air antenna. if you can not get any channel and just a white raster or snow, it could be the tuner get fried.
Jul 22, 2012 | Sony KV-32S45 32" TV
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
Tv getting snow & static sounds on all channels.
This TV, I believe, does not have a digital tuner. If you're trying to pick up channels off the air with rabbit ears or a rooftop antenna, you'll need a digital converter box. Without one, there aren't any channels for it to tune in, so all you'll get is snow and static.
If you have a converter, or are using this TV with a cable box, satellite receiver or a similar device, you may have a bad connecting cable. Be sure the cable is firmly connected and that the center pin isn't bent or too short for a good contact. It should extend an eighth of an or so past the end of the connector. Try another cable.
If this set has been working properly and the trouble is new, something is up with the tuner. It may have been damaged during a storm or from power line problems. Poor solder connections may have developed on the circuit board. Other electronic failures may have occurred. If the trouble appears to be inside the TV, it's probably not worth repairing. The replacement cost of a small TV would be not much more (if not even less!) than the labor and parts to fix it.
I hope this has helped. if so, please take a moment to give a thoughtful rating. Thanks for using Fixya!
Oct 22, 2010 | Craig CTV-41331 13" TV
Im trying to comnect this tv so i can get the local channels only- no cable. the tv comes on but the connection is not there. thank you
Go to the menu pick air,don't pick cable u get free air channels,just use a regular roof antena or a digital antena.
Dec 10, 2009 | TruTech PVS31170S1W 17 in. LCD Television
NOTHING BUT SNOW ON THE SCREEN
Are you connected to cable TV or an outdoor antenna? If on cable TV check the signal on another TV or if on an outdoor antenna you will need a digital TV adaptor to pick up local stations due to them not being available in analog anymore. Please take moment to rate my answer. Thanks...
Nov 26, 2009 | Toshiba 32D46 32" TV
No receipt of signal or antenae
Since it has voice or sound then I don't suspect the tuner but probably the tuner does not have the 33 volts that goes through r106 location number on the board. It is a 27K resistor and can be bought for about a dollar at Radio Shack. (pack of 2or3) A repairman or someone experienced in electronic soldering and desoldering can change it easily. Could cost around $50 to repair depending on the serviceman. If it has rca jacks (red, white and yellow) The tuner can be bypassed if you have a cable box that passed these signals: audio left and right and video. Hope this helps
Dec 30, 2007 | Sanyo AVM-3258S 32" TV
HD cable question
i have the same LCD and my problem was the same as you, you need a powerful antena like a out dor antena or indor antena whit buster
Dec 03, 2007 | Polaroid FLM-3232 Television
1999 RCA 62 inch tv
Does the picture come up..what is known as a raster(LIGHT) up. does it have sound.
Nov 29, 2007 | Televison & Video
No more picture and sound
Tv was showing perfect picture now it's snow solution 1 please check antena wire & its socket. 2 check for dust where wire is connected. 3 loose contact or print break near tuner. 4 tuner defective.
Sep 15, 2007 | Sanyo DS27930 27" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
