Question about Vehicle Parts & Accessories
Alarm goes off intermitently when starting BA
Factory fitted alarm goes off intermitently when starting BA falcon. Replaced cranking battery, problem still there.
Ok that happened to me. I installed an alarm without wiring oen wie and the alarm would go off even when i had the car started. There should be a yellow wire on the alarm module called accessory wire. This wire needsto be tapped into the thick yellow wire in your ignition area. For more help eail me at kuljot123@att.net.
Posted on Sep 06, 2009
Will a ba falcon sedan right front door glass fit a ba falcon ute
as the cars are BA models then anything forward of the door pillar lock will fit as they are both the same body parts
Jan 01, 2017 | Cars & Trucks
Why is my 2002ba falcon Fairmont keeps shutting down when started after been driven for 15klm and left for 30minutes
you can toss all new parts at it and still have the same problem
but that ba is going to need a diagnostic read for fault codes
you can have a read through australia ford car forum about the BA problems others have had
or have a read of the repair manual
one free download only not for resale etc etc
fordforums com au
Ford Falcon BA 2002 2005 Workshop Manuals Factory Service Manuals
Oct 14, 2016 | Cars & Trucks
Why does a ba falcon shut off when hot left for half an hour it will start again
very annoying and could be dangerous
after what has been fitted
leaves the coil packs/ spark issue
idle control sensor
02 sensor
the maf
other unknowns
a shut down like that ..could be a module of a sensor
the engine light should be on
saying the engine computer has fault codes to read
down load the free repair manual of you dont have one
only one download not for resale etc etc
good you replaced the CAS
first thought was the crank angle sensor
you toss water on it and if the car starts up its faulty
My Falcon seems to take a while to start and I have to press the accelerator as well or it will stall, whats the deal?
My 2004 BA Falcon won't start. Apparently it's low - Fixya
www.fixya.com/cars/t12343045-2004_ba_falcon_start_apparently_s_low
Apr 8, 2012 - Apparently it's low on - Ford 2005 Falcon 4.0 question. ... Ba engine generally is strong, common fault is ecu, if hard starting when cold, pour hot water on computer and it ... If the headlights do not dim or go out, then the battery is likely ok..... Automatic 2004 BA Falcon stalls while driving ... Open Questions:.
My xr6 won't start. Comes up saying immobilized. - Fixya
www.fixya.com/.../t12430461-xr6_start_comes_up_saying_immobilized
Feb 6, 2012 - My xr6 won't start. ... Question about 2005 Ford Falcon 4.0 ... you will get airbag errors popping up for a few weeks then after a while it .... in a while it willstart and run for about 20 seconds, then it dies and won't start. ... Open Questions: ...You may NOT copy or distribute the content that appears on this site ...
Ford falcon sometimes won't start - Ford - Automotive - Whirlpool ...
forums.whirlpool.net.au > Automotive > Ford
WhirlpoolOct 26, 2010 - I have a EF Falcon that has an intermittent problem with starting. ... It might take a minute or 5 minutes or persistent retrying. ... Normally if you wiggle the T-Bar around it will then start. ... motor with a rebuilt unit, I had a remove starter on myalarm, and would use the remote start while using my jack-handle to ... Worst Car You Ever Owned
Jun 1, 2012
LPG conversion problems with stalling - Ford
Jan 16, 2012
More results from forums.whirlpool.net.au
2006 Ford Explorer Engine Stalls While Idling: 24 Complaints
www.carcomplaints.com/Ford/Explorer/.../engine_stalls_while_idling.sht...
Jan 27, 2016 | 2005 Ford Falcon 4.0
Why wont my 2005 ba ford falcon start?
Have you changed the fuel filter?. Have a fully charged battery if the cranking voltage drops below 10 volts the computer can't work and it wont start.
Aug 11, 2014 | 2005 Ford Falcon
Why my 2005 ba ford falcon wont start?
Its either no spark or no gas. Remove the fuel line and carefully crank it over..are you getting any fuel? If not possibly clogged fuel filter or bad fuel pump. If yes, are the spark plugs firing. Remove number one plug lead hold close to any metal surface on engine, crank over ..spark there..strong or weak spark? No spark check coil and associated parts.
Ba falcon hub nut size
Hi just replaced the hub on 2000 au the size of the hub is 36mm the metal jacket has to do with the tension i think hope this helps cheers.
Jun 07, 2014 | 2005 Ford Falcon
ba engine generally is strong, common fault is ecu, if hard starting when cold, pour hot water on computer and it should start, also have you scanned vehicle?
Apr 08, 2012 | 2005 Ford Falcon 4.0
Intermitant car alarm problems on a 96 ford fiesta
I really don't think you have an immbobilizer, but if you are handy.. look behind dash at ignition harness try and find a blk/blu or grey wire, see if it is cut going to a relay of some sort, if so cut relay out and recoonect wires back together, see if car starts ....
Jan 15, 2009 | Crime Stopper Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
200 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
