I have a Garrity LED tuflight flashlight with 3 AAA batteries. I recently put new batteries in (the others were weak but not dead). Now I can't get it to work. I am not sure if I am not loading it all right. The batteries are in the battery case correctly but I don't know the order of the items. Battery case and then a little round thing with a spring on one side & metal on the other side. Thanks in advance.
Garrity Life Lite Emergency Disposable Flashlight http://www.allhandsfire.com/GARRITY-LIFE...Garrity Life Lite Emergency Disposable Flashlight
http://www.allhandsfire.com/GARRITY-LIFE-LITE-EMERGENCY-DISPOSABLE-LED-FLASHLIGHT?sc=24&category=273786#image1
Had a look on their web site and couldnt find that torch in their product lists. Basically with all LED lights the LED is soldered onto a small circuit board and is not generally replaceable unless you are into electronics and can solder in a new led.
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
I have a Garrity stainless steel flashlight that is approximately 6 inches long. It uses two AA batteries. The light is turned on and off using a push button on the back (push on, push off). The head-end turns to "focus" the light. The lamp, itself, is incandescent. It is 9/16-inch long, including the two 1/4-inch wire leads. The flashlight was purchased 11 years ago, and the lamp just burned out. When I called Garrity, they said they no longer had replacement parts for these flashlights. Which is strange, given you can use Part 2A001 Mineature Bulb G1.27 Base bulbs available from Bulb Town in Jacksonville, FL, as replacements. They work like a champ! If you have any questions, ask to speak to Melinda.
If its the one I have ... A battery may have failed and leaked causing it and the battery unit to become stuck. I pulled off the top of mine and pulled out the LED assembly and banged it on the bench a few times and it popped out and I cleaned it up with some baking soda and water.
