Question about Canon PIXMA IP5200 InkJet Photo Printer
Just installed a brand new ( bought this afternoon from PC World) Canon Magenta cartridge, Am now getting a message saying cannot print as the magenta cartridge is either incorrectly installed or not compatible!!! What can I do? Its the same as the one I have replaced! Is there some way of overiding this?
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
When printing images from my Canon MG6150 it isn`t printing any magenta/red shades and the magenta cartridge is brand new. Every other color is printing fine. Anyone know what this problem could be? Is it...
Use the printer application to clean the cartridge and print all the test. If the test are wrong. You should change your cartridge. Maybe you have a bad store cartridge or expire one.
Apr 30, 2011 | Canon Office Equipment & Supplies
Says there is more than one magenta cartridge installed
Try replacing the cartridges one by one, one at a time to find out which cartridge is causing this problem. May be there is a magenta chip on one of the othercartridges.
May 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Printer won't recognize the new ink cartridge
Each cartridge has a electronic chip pre-porogrammed at the factory.
If it is a reputable store they will exchange for the right color as they can return the PM to Canon as defective,
Mar 27, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
Canon PIXMA IP5200 InkJet Photo Printer Logo
78 people viewed this question
old marine
old marine
