Question about Motorola Mobility RAZR V3
Is it possible to block one individual number on my motorola v170 or do I need to barr all incoming calls? When I tried to barr incoming calls it asked me for a password and I typed it in but then it says NOT DONE! How do I do this?
  • cheryl_gr285 Sep 08, 2009
    When I get into settings, then security, it shows call barring for incoming or outgoing. When I select incoming call barring and enter a [assword it says not done. Today I found a place to create a password for call barr, but it doesn't accept it, it says register not done. How do I register?
  • cheryl_gr285 Sep 09, 2009
    I have a motorola v170!!!!!
    when I select call barring it says not done! When I go to new passwords for call barring it will not accept what I put in!
  • 4,281 Answers
First reset all settings of your motorola v170 to factory defaults.
You can reset with Menu of SETTINGS.
Aslo if it wants password try **** or 0000
Let me know if you need more assistanse.
Thanks.
Posted on Sep 09, 2009
  • 17,970 Answers
Motorola has a feature that you can restrict calls, incoming and outgoing:
MENU> Settings> Security> Restrict Calls...
You can Restrict/Allow all calls, address book, none, etc.
Sometime I block a number, I think that first, I add this numer to the directory. Check and enter de correct PASS for this operation.
I hope help you with this. Good luck.
Posted on Sep 08, 2009
  • ZJ Limited
    ZJ Limited Sep 08, 2009
    You might have to seem edit to get those features to appear...
    Call restrictions / barring
    Edit Seem 0032_0001: offset 3F: bit 6: Settings > Security > Restrict Calls (1 on, 0 off)
    Edit Seem 0032_0001: offset 04 - bit 1: Call Restriction Support (1 on,
    0 off) Security > Restrict Calls > Incoming calls > Change
    > Allow : ALL/None/Ph Book
    Once you do the seem edits you should have those options available.
  • 501 Answers
I have the manual for my V3 and looked all through the indext and read through the call section,
Here is wht you can do, you can set it to allow, Alll, None, or only the calls from you r address book.
SETTING>SECURITY>RESTRICT CALLS
Hope that helps
Rich
Posted on Sep 06, 2009
I want o update my nokia n70 but where....?
Imagine ur cell battery is very low, u r expecting an important call and u don't have a charger.
Nokia instrument comes with a reserve battery. To activate, key is "*3370#"
Ur cell will restart with this reserve and ur instrument will show a 50% incerase in battery.
This reserve will get charged when u charge ur cell next time.
*3370# Activate Enhanced Full Rate Codec (EFR)-Your phone uses the best sound quality but talk time is reduced by approx. 5%
#3370# Deactivate Enhanced Full Rate Codec( EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound
but you should gain approx 30% more Talk Time
*#4720# Deactivate Half Rate Codec
2 *#0000# Displays your phones software version,
1st Line :S oftware Version,
2nd Line : Software Release Date,
3rd Line : Compression Type
3 *#9999# Phones software v ersion if *#0000# does not work
4 *#06# For checking the International Mobile Equipment Identity (IMEI Number)
5 #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
6 #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
7 #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
8 #pw+1234567890+4# SIM Card Lock Status.(use the "*" button to obtain the "p,w" and "+" symbols)
9 *#147# (vodafone) this lets you know who called you last *#1471# Last call (Only vodofone)
10 *#21# Allows you to check the number that "All Calls" are diverted To
11 *#2640# Displays security code in use
12 *#30# Lets you see the private number
13 *#43# Allows you to check the "Call Waiting" status of your phone.
14 *#61# Allows you to check the number that "On No Reply" calls are diverted to
15 *#62# Allows you to check the number that "Divert If Unrea chable(no service)" calls are diverted to
16 *#67# Allows you to check the number that "On Busy Calls" are diverted to
17 *#67705646#R emoves operator logo on 3310 & 3330
18 *#73# Reset phone timers and game scores
19 *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it
means you will get the best standby time possible
20 *#7760# Manufactures code
21 *#7780# Restore factory settings
22 *#8110# Software version for the nokia 8110
23 *#92702689# (to rember *#WAR0ANTY#)
Displays -
1.Serial Number,
2.Date Made
3.Purchase Date,
4.Date of last repair (0000 for no repairs),
5.Transfer User Data.
To exit this mode -you need to switch your phone off then on again
24 *#94870345123456789# Deactivate the PWM-Mem
25 **21*number# Turn on "All Calls" diverting to the phone number entered
26 **61*number# Turn on "No Reply" diverting to the phone number entered
27 **67*number# Turn on "On Busy" diverting to the phone number entered
Each command is prefixed with either one or two * or # characters as follows:
** Register and Activate
* Activate
## De-Register (and Deactivate)
# Deactivate
*# Check Status
© Call button
Once each command has been entered, if it is a network command (as opposed to a local handset command) it must be transmitted to the network by pressing the YES (receiver) key which acts as an enter key - this is represented here with the © character. Always enter numbers in full international format +CountryAreaNumber ( e.g. +447712345678).
Command Description Command String
Security
Change call barring code **03*OldCode*NewCode*NewCode#©
Change call barring code **03*330*OldCode*NewCode*NewCode#©
Change PIN code **04*OldPIN*NewPIN*NewPIN#©
Change PIN2 code **042*OldPIN2*NewPIN2*NewPIN2#©
Unlock PIN code (when PIN is entered wrong 3 times) **05*PUK*NewPIN*NewPIN#©
Unlock PIN2 code (when PIN2 is entered wrong 3 times) **052*PUK2*NewPIN2*NewPIN2#©
Display IMEI *#06#
Call Forwarding (Diversions)
De-register all call diversions ##002#©
Set all configured call diversions to number and activate **004*number#©
De-register all configured call diversions (no answer, not reachable, busy) ##004#©
Unconditionally divert all calls to number and activate **21*number#©
Activate unconditionally divert all calls *21#©
De-register unconditionally divert all calls ##21#©
Deactivate unconditionally divert all calls #21#©
Check status of unconditionally divert all calls *#21#©
Divert on no answer to number and activate **61*number#©
Activate divert on no answer *61#©
De-register divert on no answer ##61#©
Deactivate divert on no answer #61#©
Check status of divert on no answer *#61#©
Divert on not reachable to number and activate **62*number#©
Activate divert on not reachable *62#©
De-register divert on not reachable ##62#©
Deactivate divert on not reachable #62#©
Check status of divert on not reachable *#62#©
Divert on busy to number and activate /td> **67*number#©<
Activate divert on busy *67#©
De-register divert on busy ##67#©
Deactivate divert on busy #67#©
Check status of divert on busy *#67#©
Change number of seconds of ringing for the given service before diverting a call (such as on no answer). Seconds must be a value from 5 to 30. De-registering the same divert will also delete this change! **service*number**seconds#© (Service numbers, see below)
Call barring
Activate barr all outgoing calls (see Security to set code) **33*code#©
Deactivate barr all outgoing calls #33*code#©
Check status of barr all outgoing calls *#33#©
Activate barr all calls **330*code#©
Deactivate barr all calls #330*code#©
Check status of barr all calls /td> *#330*code#©<
Activate barr all outgoing international calls **331*code#©
Deactivate barr all outgoing international calls #331*code#©
Check status of barr all outgoing international calls *#331#©
Activate barr all outgoing international calls except to home country **332*code#©
Deactivate barr all outgoing international calls except to home country #332*code#©
Check status of barr all outgoing international calls except to home country *#332#©
Activate barr all outgoing calls **333*code#©
Deactivate barr all outgoing calls #333*code#©
Check status of barr all outgoing calls *#333#©
Activate barr all incoming calls **35*code#©
Deactivate barr all incoming calls #35*code#©
Check status of barr all incoming calls *#35#©
Activate barr all incoming calls when roaming **351*code#©
Deactivate barr all incoming calls when roaming #351*code#©
Check status of barr all incoming calls when roaming *#351#©
Activate barr all incoming calls **353*code#©
Jun 03, 2011 | Nokia N70 Cellular Phone
LG Cookie T310 - how do i bar phone sales calllers, is there a univesal pin code? The phone was sold without a maunal (which is hopeless as i have features and no way of working out how to use them!) and...
Hi,kindly click on menu key,then click on settings,then scroll to call settings,you then click on call barring,you can barr all type of calls.either;
International calls,outgoing,incoming. Etc.you then click on the one you want to activate it.that will get your calls barred.but always remember you can't barr just a number.
Take care.
May 25, 2011 | LG Cell Phones
How to block contacts from calling me ???
Hello
All you need to do is to go to settings on your mobile phone,then you go to phone settings or call settings to locate call barring.After that then you would list the particular contacts number you want to block and if you want to block all contacts,then you would choose Barr all incoming calls.
THANK YOU FOR VISITING FIXYA
Aug 10, 2010 | HTC Touch Viva Cell Phone
I have a Motorola RAZR and would like to block an incoming number
Yes you can block the caller.
Some phones give you the option of blocking a number actually on the handset or.
You can phone up your service provider and tell them you keep getting constant calls from a number and ask them to barr it for you or
You could answer the person calling and tell them that the person they are trying to reach no longer has that number and you would appreciate it if the ceased calling you.
Jul 16, 2010 | Motorola Mobility RAZR V3
How do you remove barred from a number
You cannot barr or unbarr a single number, you can only barr a group of numbers, for instance all international incoming calls, local incoming calls, etc.
To unbarred a group of call,
Go to your phone menu,
Select your settings,
Select call settings,
Select call barring,
Select unbarred all.
And the call will be unbarred.
take care
Jun 20, 2010 | Samsung B2100 Cell Phone
How can I block a phone number from calling me?
It is an handsetbased feature. I know of erricson for this but you can barr all incoming calls.
*35*0000#
Apr 19, 2009 | LG Vu CU920 Cellular Phone
Volume of my voice on Motorola V170 trakphone
the phone's Microphone or Microphone IC is faulty. replace the Mic its under this place. or even just clean it maybe some dust would defect it.
.please rate this post as good as u can so we can help others.
Feb 02, 2009 | Motorola Mobility RAZR V3
All incoming calls go straight to voice mail
Just go to call settings and then call divert. check settings. Maybe all calls are diverted to voice mails. Cancell all diverts. Then you are done.
Jan 21, 2009 | Motorola Mobility TracFone® V170 Cellular...
V170 text problem
Did u try calling you're cellphone company to know if they blocked the text messages ? If you're text messages are not block, can you tell me more on what happens, what error/messages you get or simply what you do
Jun 16, 2007 | Motorola Mobility V170
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
