Question about Hoover F6213-900 SteamVac Agility TurboPOWER Steam Vacuum Vacuum
Hoover steam vac dual brushes will not turn.
I have cleaned the filter and the brushes but they still will not turn. I have followed all directions in the manual. Everything else works fine.
    Problem Solver:
  • 12 Answers
The belt is broken.
Posted on Sep 07, 2009
  • 636 Answers
Have you tried checking the drive belt?
drive belt is located on the bottom side of the power head ,remove all the Phillips screws from the bottom and pull the plate off . Remove the brush bar by pulling it straight out this will expose the belt. Belt is gray in color, replace belt around the drive pulley and also around the brush bar, align the bar and push back into place, rotate until the belt is centered and reinstall plate and screws.
My Dyson DC33 isn't working correctly. It's not picking up like it used to. The brush isn't turning and the belt is fine. I've checked all filters, hoses and cleaned everything. Why is the brush not...
Is it possible that you have accidentally changed the brush control setting? I say this because it happened to me and I thought it had broken. I must have caught the dial with my foot! Here a link that might help:
Jul 09, 2014 | Dyson DC33 Bagged Upright Vacuum
F7441-980 brushes won't turn
Paul:
Turn the vacuum over and remove the foot plate. Check the belt and manually try to turn the brushes. If the belt is OK, the brushes need to be removed and the roller bearings at the end of the brushes cleaned (hair, fibers, dust,) I remove the roller bearings and shoot them with alcohol while turning them until they turn free, then blow the alcohol out and lube them with one drop of light machine oil.
Nov 29, 2013 | Vacuums
Roomba appears to be working fine, goes over the whole house with no trouble, but then house is still dirty and no dirt is in his dirt bin.
if there is dust in the filter and none in dirt bin check to see if brushes are turning, you can do this by running the roomba with bin out, if not turning clean thoroughly, remove yellow tips on ends to check for trapped hair, replace brushes and turn them manually in one direction a few times and then run roomba again, you may need to do this a couple of times
Sep 08, 2010 | iRobot Roomba 560 Robotic Vacuum
The brushes on my Hoover steam spin carpet cleaner will not spin.
Hello, their is two reason why the brushes don't spin, one would be the brush brock is broken, take out the brush, and mnake sure their is a plastic two inch shaft sticking out, if not, then the brush block needs to be replaced, if fine, the the turbine is frozen and will need to be replaced, take the lid off and replace the black turbine, I can send you anything you need, or if you have any questions feel free to call 1561-848-3387 Thank you, Teresa.
Clean sweep Vacuums
Aug 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
Brushes won't turn
the mechanisam that makes the brushes spin are broken. take it into a shop dont fool with a roomba
Sep 11, 2009 | iRobot Roomba 560 Robotic Vacuum
Unit wont turn on.
might be the switch is bad ore lose connection for the wire came off the plug
Jul 23, 2009 | Bissell 6594 PowerForce Bagless Upright...
Brushes not working
brushes not turning are usually caused by the turbine bearings have seized. The turbine cost is about $35 average. on the bottom you can check a pull out filter to clean. there are also 2 screws that are recessd check by hand for tightness that hold the turbine. checkthe brushes for cleaning and free of debris. check the square shaft on the brushes as well. take it to a trusted vac shop who works on hoovers if you are not mechanically inclined for this type of repair.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 15, 2009 | Hoover F7431-900 SteamVac Vacuum
The Brushes stopped spinning
I clean mine with a chopstick. *shrugs* No way that we can see to take it all apart. Did you clean the filter thing right next to the brushes? hoover.com has manuals to everything they sell unless it's reaaaaaly old. :-)
Nov 29, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Brushes do not spin
The manual suggests cleaning the filter screen near the brush assembly. This is located on the bottom of the unit. In cleaning this it did not successfully help. I then proceeded to take the cover (blue) off the motor an brush drive and worked my way to the gear assembly. This is where I found the actually problem.
The problem: The brushes are driven by a turbine wheel operated with suction from the vacuum. In my unit the turbine and bearings became loose or slipped to the point that the worm gear lost contact with the additional gears that drive the brush. When resetting the assembly so that ample contact is established the unit began to operate fine.
This can be complicated to explain and illustrate therefore taking the unit in for repair is recommended. If you are confident in repairing the unit yourself then go for it.
Jul 28, 2008 | Hoover F7452-900 SteamVac Upright Vacuum
Hoover F6213-900 SteamVac Agility TurboPOWER Steam Vacuum Vacuum Logo
398 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
