Question about Singer 2950 Mechanical Sewing Machine
Bobbin thread bunches up in machine - Singer 2950 Mechanical Sewing Machine
  • 1,889 Answers
Remove bobbin; remove spool; look on side of bobbin case for a tiny screw (bobbin tension) adjust screw untill top and, bottom thread lock is the same
Posted on Sep 06, 2009
I have a Singer 2263 which is old but not used often. I am making aprons for Christmas, I made 3 and all the sudden the bobbin started bunching together. What can I do?
hi Sue.
Why does my bobbin thread keep bunching up? Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimes thread bunching can be caused by something as simple as the tension dial being inadvertently turned.
Sewing Machine Thread Bunching Up Here Why .
if you go to this link a little pop up will come up just close this down.
or try this one.
How to Fix that Tangled Nest of Bobbin Thread Under Your Sewing
or read up more at this link.
Why does my bobbin thread keep bunching up Google Search
Dec 13, 2017 | Singer Sewing Machines
The bobbin thread is bunching up
hi Lois.
this is all i could find out.
Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimes thread bunching can be caused by something as simple as the tension dial being inadvertently turn.
or try this link.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
or this one,
if you go to this link a little window might open up in the middle of the page just close the little window down.
or this.
The bobbin thread is bunching up Google Search
Dec 12, 2017 | Sewing Machines
Thread bunches up into a knotted mess on bottom. Bobbin doesn't sit flat inside the bobbin case but spins with a tilt, lower on the left and higher on the right. Bobbin touches plastic cover plate.
Usually, thread bunching under the fabric is an upper tension issue. Be sure to ALWAYS RAISE the presser foot when threading the upper thread.
With the bobbin case operating at a tilt, there is something mechanically wrong with the machine. It may be best to take it for service.
Aug 30, 2016 | Singer 4411 Heavy Duty Sewing Machine
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Thread bunches up when replacing thread on bobbin
If the thread is bunching or tangling when winding a bobbin, check that you have properly threaded the winder. Especially make sure you are running the thread through the bobbin tension assembly.
Aug 21, 2014 | Singer 5050 Mechanical Sewing Machine
Brother pe180d thread bunching up underneath
try changing the needle
rethread the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and that the bobbin is turned the right way
make sure the thread has not come off the thread take up lever
if the machine continues to see bunch thread underneath then the
machine may need to be checked to see if some part has become
damaged or out of alignment
Dec 02, 2012 | Brother Disney PE-180D Computerized Sewing...
When i sew the bobbin thread bunches up. what to do?
remove the thread and bobbin.
take out your manual and follow the exact instructions for threading and inserting bobbin.
If this does not help check the tension on the top(the number should be about mid way).
If it is too low it will bunch up on the bottom.
Nov 12, 2011 | Brother LS-1217 Mechanical Sewing Machine
Can't set the tension on needle or bobbin to match
1. make sure your machine is threaded right.2. set the tension between 3 and 4 and play with the tension as you need it to adjust it.3. make sure the bobbin is threaded right.make sure to visit the site below; it has solutions to multiple problems and instructions how to thread the needle or bobbin. Good luck.htt://Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Aug 03, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
I have a WHITE 3300 EMBROIDERY MACHINE and the thread bunches up at the bobbin site. I have tried a new needle, adjusted upper thread tension , changed bobbin threads and nothing helps, it keeps bunching...
Refer to your machine for cleaning the bobbin area.
You will need to clean this area often as lint and thread snips can build up can cause the bobbin feed to malfunction.
If this continues after you have cleaned the machine, the timing may need to be adjusted by a sewing machine tech.
Mar 18, 2010 | White Sewing W3300 Computerized Sewing...
My new sewing machine, just opened to use, is bunching thread on the underneath or bobbin side when I attempt to straight stitch. What is causing this to happen. Thanks.
re thread the top and bobbin threads
after pulling up the bobbin thread pull both threads to the back and hol them when stitching the first few stitches
with out holing the threads the machine will pull the thread into the machine and bunch the thread
Aug 24, 2009 | Kenmore Sewing Machines
Singer 2950 Mechanical Sewing Machine Logo
176 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
