Question about HP PSC 2175 All-In-One InkJet Printer
Cartridge The printer keeps stating right cartdrige incorrect, I take it out and repace it, the it will state cartdrige jam. I take it out and it states incorrect again. Help
  • pam8660 Dec 09, 2007
    put a new ink cartridge in--it says there is a problem w/ right cartridge....remove and replace...replaced with a totally new one still says the same thing...(both cartridges are brand new)?????
    Genius:
  • 1,003 Answers
REMOVE BOTH INK CATRIDGES WIPE THE BACK OF THEM ( THE CONTACTS)OFF WITH RUBBIng ALCOHOL applied to a micorfiber towel AND REINSTALL THEM then try to print
Posted on Jan 17, 2008
Carriage is jammed in the right position, can't move at all.
the ox4d is an error stating that it's not recognising a printer cartridge.
this error can be cleared, by putting the old cartridge using the cartridge replacement process, then powering off both printer and computer, then power both back up again and performing the replacement again.
is the carriage jammed (printer cannot move it?)
Jan 10, 2016 | Epson Workforce 610 All-In-One InkJet...
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
I purchased ink that stated that it was compatible with my R220. It worked fine for a short while and then I got a message that the cartridges were "not compatible" and it stopped printing. I...
possibly because you bought non-original cartridge (it does not recognize the printer). Try to mount the old ones again and see if you recognize the same message persists imprimanta.Daca ignorance of cartridges means that problem is another possible carrier on the outer cartusele.If with the old cartdriges you have another message then it is a problem with the new purchased cartdriges and should replace them
Feb 24, 2011 | Epson Stylus Photo R220 InkJet Printer
Printer wouldn't work - said cartridge jammed - I took coloured one out - can't now get it back and the other one will not go into middle of printer for me to but the one back into position
Hi Good daY!!! Check your printer if there is something that block your print head. after that turn off your printer and then move the cartridge into the center and then remove the ink cartdriges. after that turn on your printer without the ink cartridges, now your printer will recognize that your ink cartdriges is missing after that insert the ink (insert it properly) and then see if your printer would work now.
Thank you for using FixYa
Please accept if my solution helps you
Nov 14, 2010 | Dell 924 All-in-One InkJet Printer
States "Right Cartridge incorrect"
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 30, 2010 | Dell 922 All-In-One InkJet Printer
HP Photosmart 3110 All in One says ink cartdriges missing
Follow the instructions in this link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00409514&prodTypeId=18972&prodSeriesId=3380537
May 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
Changed cartridge and
Hi
Sw off and sw on the printer , Replace the cartdrige and then restart your pc. some time because of cache you need to flush it hence .
Feb 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Align printer
Go to "Printers and Faxes" in the start menu. Then right click on your printer and click on properties. Then click on the tab called Maintenance. There should be a button to align the print heads. Make sure the printer is on and paper is in the tray before trying to align the print heads.
Oct 07, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
"Clear carriage jam" persistent error...
I got the error message about clearing the carriage and no matter how many times I turned it off, unpluged, turned in on again, checked for paper jams, etc, the printer could not get reset. But after much trial en error, the following procedure did the trick: Unplug the power cord and open the door. To the right side, you'll see the ink tray. Carefully pull it to the center and unistall the ink cartriges. Close the door, plug in the power cord and turn the printer on. It should ask you to install the left ink cartrige first. Do it and close the door again. Then it'll ask you to install the right cartrige. Do it as well and turn the printer off again. Turn it back on, let it initialized, and your printer should be ready to work again. I hope this work for you as it did for me. Good luck.
Feb 08, 2006 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 2175 All-In-One InkJet Printer Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
