After Windows has started and the setup screens show, my Kogi monitor says "out of range" and the screen goes black. How can I fix this?
    President:
  • 3,278 Answers
When you switch from a CRT to LCD, your refresh rate will decrease. This is easily completed by changing the refresh rate on your computer. To make this adjustment please connect your old CRT monitor to your computer.
1) Open the Control Panel (located in the Start menu, Select [Settings].)
2) Double click on the [Display] icon.
3) Select the [Settings] tab and adjust the [Screen Area] setting by moving the indicator bar to the right. Your appropriate setting is based on your screen size.
12.1" LCD, 800x600
14.1" or 15" LCD, 1024x768
17" or 19" LCD, 1280x1024
4) Select the [Advanced] button located in the lower right corner,
5) Click on [Monitor] or [Adapter] tap.
6) Select a Refresh Rate/Frequency of 72 Hz or lower.
7) Select [Apply].
8) Select [OK] to keep the settings.
9) Shut down your computer.
10) Connect your new LCD monitor to the computer WHILE IT IS OFF.
11) Turn on the computer and LCD monitor at the same time. This will resolve your issue.
Good luck.
Posted on Sep 06, 2009
  • 3,153 Answers
Set the resolution lower.
It is telling you that the resolution you want is beyond its normal operating range.
just drop it to lets say 800 x 600
Then bump it up one resolution at a time until you get the message again, then drop it back one.
Running monitors above the acceptable range can drastically shorten their lifespan.
The issue is that I had an XP machine and I bought a brand new HP deskktop Windows 7 and as soon as I turned it on I got a message on my Kogi that I should change the settings to 1280 X1024. Since I did...
To change the screen resolution, click on Start - Control Panel - Display - Settings tab and the adjust the screen resolution slider to 1280X1024 click Apply.
Feb 03, 2011 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
When I hooked up my Kogi monitor to a computer running Windows Vista, the screen said "out of range" and I couldn't do anything with it. Any suggestions? Thanks.
out of range means you had the resolution to high
set it to 1024 X 768 and see what happens
go to control panel and choose display to change this setting
http://www.tweakguides.com/images/ATICAT_5.jpg
Dec 29, 2009 | Kogi L7CH Monitor
I have this monitor and just bought a new computer. When the computer boots up and gets past the "windows" graphic monitor goes black. It worked fine with my old computer and my new computer works with an...
You may try the following steps:
Boot the computer in safe mode.
While booting press the F8 key and on the Windows Advance boot screen, select safe mode and press enter.
Once you are on the logon screen, select Administrator account.
Click on Start and rightl click on My computer, then click properties
Go to hardware tab and click on Device manager.
In the device manager look for Display adapter, Click on the + sign, right click on the listed devices and uninstall.
Now you should be able to boot the computer in normal mode.
Please let me know if you need any further assistance.
If you find this solution helpful, please do not forget to leave your feedback and ratings.
Thank you for choosing Fixya.
Nov 27, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Upgraded to win 7 now princeton monitor goes black how do i fix
try this, but a bit tricky.
start off with the pc off
then turn it on
wait till the bios etc splash screen show past the hit del or f2 to goi to setup then after that press f8 repeatedly until it shows some sort of list
this is the alternate boot up just scroll down to ENABLE VGA MODE
after selecting that it will boot up with your screen..
hope that works
Nov 10, 2009 | Computers & Internet
Kogi L9CH monitor - black screen
return for a replacement, the screen is broken
Sep 13, 2009 | Kogi L9CH 19" Flat Panel LCD Monitor
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
Blank screen
try to reinstall the drivers of your video card while you are in safe mode.
Aug 25, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi l4ax monitor (black screen)
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went blank, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. You might go get technician to fix it. Hope this help!! If anything I can help you with, feel free let me know.
Thank you,
Tan
Mar 06, 2008 | Kogi l4ax 14.1" Flat Panel LCD Monitor
Computers & Internet Logo
264 people viewed this question
David Payne
David Payne
