I have an HP Pavilion tx2000 with which I connect to the internet. In device manager under Network adapters I have: Bluetooth Device (Personal Area Network); Bluetooth Device(RFCOMM Protocol TDI); Broadcom 4321AG 802.11a/b/g/draft-n Wi-Fi Adapter, Nvidia nForce Networking controller When I check the speed of my connection it is 1mbs - soooooo slow. A wee bit of research seems to indicate that this is the maximun for bluetooth connections. Is there any way to disable the bluetooth technology and so connect at a faster speed - my ISP is Virgin Media and my other computers connect wirelessly at 3mps Thanks
  • 5 more comments
  • jcstaylor2 Sep 06, 2009
    Yes, this computer is also connecting wireless to my internet.
    I checked the speed by going to Network and sharing centre- I'm using Vista - , clicking on View Status for the wireless network connection. I did this several times and each time it said 1mps. Each time the signal strength was "Very Good" or "Excellent"
    Ironically - when I went through the same procedure just now, it says 36mps - just to prove me wrong!
    the laptop belongs to my (disabled) sister who uses it for accessing photos and music on the web - and it has been proving frustratingly slow - so I'm supposed to "sort" it!
    Any help much appreciated
    OK:
    First test came in at: Download speed 301kbps; upload 60kbps
    Second test: Download 162; upload 46
    Would another computer nearby also using wireless connection with the same router affect the laptop's connection?
  • jcstaylor2 Sep 07, 2009
    I did the same test on a neighbouring computer at the same time and it came out at download 3514kbps, upload 485.
    so it looks to me like a problem with this particular laptops wireless connection - which is what sent me down the bluetooth route in the first place.
    thanks
    Good morning - this morning I ran the test on the problem laptop and another right beside it - both at the same time and the laptop came in at 218/82 whereas the other came in at 3503/487
    Just to confirm that they are both wireless, same router, same network
    thanks
  • jcstaylor2 Sep 08, 2009
    I have an HP Pavilion tx2000 running Vista with which I connect wireless to the internet. In device manager under Network adapters I have: Bluetooth Device (Personal Area Network); Bluetooth Device(RFCOMM Protocol TDI); Broadcom 4321AG 802.11a/b/g/draft-n Wi-Fi Adapter, Nvidia nForce Networking controller When I check the speed of my connection it is 1mbs - soooooo slow. A wee bit of research seems to indicate that this is the maximun for bluetooth connections. Is there any way to disable the bluetooth technology - would this enable me to connect faster?
    My ISP is Virgin Media and my other computers connect wirelessly at acceptable speeds Thanks
    I checked the speed by going to Network and sharing centre- using Vista, remember - clicking on View Status for the wireless network connection. I did this several times and most of the time it said 1mps, very occassionally it says 36mps. Each time the signal strength was "Very Good" or "Excellent"
    using speedtest.bbmax I ran the speed test several times when I was getting connection at 1mps
    - I did the same test on a neighbouring computer at the same time and it came out at download 3514kbps, upload 485.
    thanks
    Hi, thanks for replying
    I have done that - control panel -> bluetooth devices.
    there is nothing there and if I go to the options tab the box for "Allow Bluetooth devices to connect" is not ticked
    so went to Hardware tab - got Microsoft Bluetooth Enumerator and HP Integrated Module with Bluetooth 2.0 wireless Technology. For both I went to Properties then Driver tab and clicked disable. Restarted the computer.
    Now connected at 18-36Mbps
    Question: in your opinion, will this affect the connect speed of the wireless connection, i.e. make it reliably faster than the current tendency to 1Mbps ?
    Thanks for your help
    Thank you - this would sort things out for my network here but when I give the laptop back to my sister it accesses the network there and so changing the channel here wouldn't solve the problem on other networks.
    I've decided to abandon the problem for now.
    Thank you for your assistance
  • 4,281 Answers
Yes you can disable bloe tooth .
Open control panel and go to bluetooth connection . If you can't find it there then go to device manager then right click on your bluetooth driver then disable it.
For get device manager go to my computer property then hardware ->device manager.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 08, 2009
  • I think blue tooth not conflict with wi fi .
    There is reason of may be wi fi network adapter.
    You can do more trouble shooting that uninstall wi fi network adapter driver then install again.also some times Channel type is issue.
    But you tell me that other computer give better speed with same router settings .Though you can do this thing.
    For that access your router with following link
    http://192.168.1.1
    or
    http://192.168.0.1
    type user name as "admin" and password as "admin" or blank or "password"
    then go to advanced then channel type 4,6,11 is best.
    Try 1 by 1 then save settings and restart both computer and router .
    Thanks.
Hi there
Is this computer connecting wireless to your internet also or is it wired to the router/modem?
It is most likely the Bluetooth connection is not used for the Internet. You can disable the Bluetooth connections, but they won't have any affect on your Internet speed.
How did you check that you are getting 1 Mbps?
Please do not rate this reply unless I have answered your question or your reply will not be returned to me. Thanks.
Posted on Sep 06, 2009
  • Anonymous Sep 06, 2009
    It is quite possible it was still negotiating a wireless throughput when it first started connecting to the router after turning the laptop on.
    See if it still shows 36 Mbps from now on. That will confirm if it is connected well.
    If it shows 1 Mb more often than the higher 30 Mbps, please test the internet connection here from this laptop and let me know the results.
    Thanks
    Thanks for testing. The other computers shouldn't affect Internet speed or even the remaining wireless speed unless they are downloading serious amounts of data at the same time. I understand the other laptops are not suffering the same problem? Would you be able to test the same speed test website with one of the unaffected laptops please?
    The results so far do show either a slow broadband or wireless connection. Testing with the other laptop will confirm.
    Thanks
How to enable bluetooth on my hp pavilion dv7
link to driver if not installed alredy
if driver installed :
Check that your PC has a built-in Bluetooth device by consulting its user guide. If it does not, you'll need to buy an external receiver often referred to as a "dongle" and connect it to a spare USB port.
Ensure that your wireless and Bluetooth receiver is turned on. Touch the antenna symbol next to your PC's volume control. It will turn blue when it's on and amber when it's off.
Go to the "Control Panel" from the start menu and select "HP Wireless Assistant" if you're using XP. You'll need to go via "Network and Internet" if you're running Vista or Windows 7.
Make sure your Bluetooth adapter is enabled. If you get a warning that it's not, click on "Windows Device Manager," right-click on your Bluetooth device and select "Enable."
Go back to the "HP Wireless Assistant" window and press the "Turn on" button next to the Bluetooth icon if it's not already showing as being activated. Your Bluetooth device is now on and you're ready to connect to another enabled unit.
Jul 26, 2011 | HP Pavilion dv7-1132nr Notebook PC
No wireless adapter
Have you check the wireless card under the Device Manager?
Start->Control Panel->Device Manager
Under Device Manager look for Network Adapter there will be sub folders under network adapter look for the wireless device. If its not showing it means that the Device is not working. If you want to make sure try to reinstall the Operating System and after that check again the Device Manager.
Mar 30, 2011 | HP Pavilion TX1320US Tablet PC
Cant work bluetooth
The first thing that I would advise you to do is,
Uninstall the bluetooth Adapter totally from the System first,
(For WIndows XP)
Right-Click on my computer Icon, Properties-->Hardware-->Device Manager,
select the bluetooth Adapter under network adapters, and right click on it, then select uninstall
Next, Click on Action on that Same page, and select "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your bluetooth Adapter).
(For WIndows Vista)
Right-Click on my computer Icon, go to
Properties-->>Device Manager, select the bluetooth Adapter under network adapters, and right click on it, then select uninstall
This will also bring up a prompt to install the new hardware found (Which is your bluetooth Adapter).
After this, Press your bluetooth button on the system and ensure that it is On, then Scan for bluetooth devices.
It should connect like that.
Try this out and kindly let me know how it goes,
Hope this helps.
Thank you for using Fixya.
Goodluck
Jul 28, 2010 | HP Pavilion Tablet Notebook
Windows 7 Pro 64 Bit and No Internet
It sounds to me like you need a new driver for the LAN adapter that is compatible with Windows 7 64 bit. Right click on Computer under the start menu, chose manage, and open the Device Manager applet. Look for your network card under Network adapters. Right click on your adapter and click on properties. Go to the driver tab and click on update driver. You can also try uninstalling the driver from there and then have the computer scan of new hardware from the device manager screen and let Windows reinstall the driver. Let me know what you find so I can help you further troubleshoot if this does not fix the problem.
Jan 08, 2010 | HP Pavilion a1600n (882780776265) PC...
I installed net stumbler on my HP pavilion dv5 with NDIS 5.1 wireless card. but it said access is denied. i connect to the internet through a wired cabled connected to my modem.
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 07, 2009 | HP Pavilion DV5234US Notebook Laptop
HP built-in wireless internet light cannot be
try this...
Windows WiFi Fix,
Windows XP:
Click Start
Click Disable
Windows Vista:
Click Start Logo
Click Disable
Oct 03, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion PC wireless light stays amber regardless of where I set the switch. Does not recognize my wireless network.
Switch on those generally is on when it is shifted to the right. Light will stay amber as long as the device is not active. If the switch is to the right, I would suggest trying this fix to see if you can get it to work.
Windows WiFi Fix,
Windows XP:
Click Start
Click Disable
Windows Vista:
Click Start Logo
Click Disable
Sep 29, 2009 | HP Pavilion dv9000z Notebook
Cant connect to my wireless network anymore???
NVIDIA nForce Networking Controller drivers may have messed up your network drivers , since your network card is broadcom or intel pro, and it is not there.
Try reinstalling the wireless lan drivers.
You can download the wireless network card driver from link below:
Select software and drivers
In there you find different wireless drivers, download and install them all, the computer will automatically chose the correct ones.
You will have to enter your wireless network key again after reinstalling drivers.
Feb 18, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Internal Bluetooth Adapter won't work...
hi...
first what we need to check if the bluetooth software is installed or not,right click on my computer and go to properites,once you click on properties,click on the tab that says advacned and underneath this box you will see an option which says device manager,click on device manager and check if the bluetooth adapter is listed under the category that says bluetooth or network adapter,if you see that there is no yellow question mark under bluetooth option,if there is a yellow question mark then you probably need to reinstall the drivers...if the software is listed and yet it is not getting detected probably we need to reset the bluetooth adapter and also make sure if the bluetooth light on the laptop is on or not,the light is situated on the front of your laptop...
incase the device manager looks perfect then go ahead and reset the bluetooth card
link to download drivers for vista...http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-56755-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3747258
here the manual that u can download to see how you can reset the bluetooth card...http://h10032.www1.hp.com/ctg/Manual/c01295898.pdf
vedhick
Feb 10, 2009 | HP (PH075AV) Bluetooth Wireless Adapter
Enabling bluetooth
Are you sure that bluetooth is installed? You should be able to look in the Device manager, usually listed under Network Adapters to see if there is such a device. If so, it is usually enabled using the HP network configuration icon in the Tray (where the clock is on the right hand side of the taskbar).
Apr 06, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
