Question about HP Photosmart C5180 All-In-One InkJet Printer
HP C5180 won't print on photo paper
Only prints on 8 1/2 X 11 paper even after reinstalling software on my Apple (OS X 10.5) I have connected with usb cable and downloaded the appropriate software but no improvement
I am trying to hook up my HP C5180 printer to my linskey router so I can print wirelessly from my laptop and I am having problems. I followed the directions on the HP web site and downloaded the drivers...
You need to check for Apple Software Update for printer Drivers. Download the updates and install and it will list the available printer on network
Regards,
Sean
Feb 25, 2013 | HP Photosmart C5180 All-In-One InkJet...
When asked to print my c5180 all in one ejects blank sheet of paper making no attempt to print
Just click below for more information;
s.gif » Macintosh: All-in-One Ejects Blank Page or Pages in Mac OS X V10.4
Mac OS X V10.4: A blank page or pages emerge from the product when it is turned on. s.gif » A Blank Page Prints at the Beginning of Every Print Job ...
A blank sheet of paper prints at the start of every print job. s.gif » Load Paper
Instructions on loading paper and envelopes. s.gif » When I Try Printing in Windows Vista, My Printer Is Not Available in the List of Printers ...
Windows Vista: The product does not appear in the printers folder when attempting to print on a network. s.gif » HP Photosmart C5180 All-in-One Printer: Manuals
... HP Customer Care | HP Photosmart C5180 All-in-One Printer | Product information HP Photosmart ... One Printer | Product information HP Photosmart C5180 All-in-One Printer: Manuals About these files: These
Hope this may help;
Regards,
VOTIT
Aug 23, 2008 | HP Office Equipment & Supplies
Can you just give me a link or quick advice on scanning with HP photosmart c5180? I would like to to scan and save to disk/save to laptop.
Scanning with HP Solution Center Software in Windows
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search#N43
FROM THE MANUAL ON PAGE 14 http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Scan an image You can start a scan from your computer or from the HP All-in-One. This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning. ? On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running. Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software. ? On a Mac, the software is always running. Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One. To save a scan to a memory card 1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One. 2. Load your original print side down in the right front corner of the glass. 3. Press the Scan Menu button. 4. Press to highlight Scan to Memory Card, and then press OK. The HP All-in-One scans the image and saves the file to the memory card in the JPEG format. To scan a photo and reprint it 1. Press Reprints. 2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following: To reprint your original photo using the default print settings ? Press Print Photos. To change print settings before reprinting your original photo a. Press OK. Basics Guide 13 HP All-in-One overview b. Press or to highlight a paper size, and then press OK. The paper size choices available vary depending on your country/region. Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages. c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK. The HP All-in-One scans your original and shows a preview of the photo on the display. d. Press OK to display the selection menu. Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies. If you want to edit the photo before printing, press to highlight Edit Photo, and then press OK. e. Press to highlight Done, and then press OK. The Print Summary screen appears. f. Press or to highlight one of the following options, and then press OK. Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and time stamp on your photo. By default, the Paper Type is set to Automatic and the Date Stamp setting is set to Off. If you want, you can change the defaults of these settings with the Set New Defaults option. Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and wasting paper and ink on potential mistakes. Print Now Prints your photo with the size and layout you selected. To scan to a computer 1. Load your original print side down in the right front corner of the glass. 2. Press Scan Menu. 3. Press to highlight Scan to Computer, and then press OK. 4. If the HP All-in-One is connected to one or more computers on a network, do the following: a. Press OK to select Select Computer. A list of the computers connected to the HP All-in-One appears on the display. Note The Select Computer menu might list computers with a USB connection in addition to those connected through the network. Chapter 1 14 HP Photosmart C5100 All-in-One series HP All-in-One overview b. Press OK to select the default computer, or press to select a different computer, and then press OK. The Scan To menu appears on the display, listing the applications on the selected computer. If the HP All-in-One is connected directly to a computer with a USB cable, proceed to step 5. 5. Press OK to select the default application to receive the scan, or press to select a different application, and then press OK. A preview image of the scan appears on your computer, where you can edit it. 6. Make any edits to the preview image, and then click Accept when you are finished.
Jun 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
I am trying to print my holiday photos. But my photosmart C5180 printer will not print borderless. There is a white border on the right side on app. 5 mm and 5 mm on the top.
Go to HP Solution Center
Go to printer settings
go to Printer preferrences
go to features tab
choose or check on borderless
Printing on Special media
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=57671&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=1153481
Printing
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=57688&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=1153481
Mac OS X: Printing Borderless 10 x 15 cm (4 x 6 inch) Photos
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00846942&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search
Mar 26, 2011 | HP Photosmart C5180 All-In-One InkJet...
My Inspiron 531 has vista os. recently, i had to
You would need to download the software for your printer again and then install it on your computer. You can download it from here. Once it is installed, look for the scanner icon or HP Director which would have scanner icon.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=1153481
Download the first link from the list.
Nov 18, 2009 | HP Photosmart C5180 All-In-One InkJet...
My All In One 6180 doesnt find photo paper tray
Works on my mac You need to check your print dialogue box more carefully This is operator error- or driver inkypete
Apr 15, 2009 | HP Photosmart C5180 All-In-One InkJet...
I can't seem to print borderless photo prints
Ok,
After going back and forth with Hp which by the way were very helpful I still did not get a fix. I decided to go to "Control Panel" Clicked on "Printers and Faxes". Right clicked on my printer icon and deleted it. Then I clicked on "Add a printer" I added the C5180 again and now it works great. Don't know why and I don't care. Just so it works again. That's the nature of computers sometimes. Thanks
Feb 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error oxc19a0024
Well i would recommend you to uninstall & reinstall the printer software... just make sure that the printer is not connected to the system when you are reinstalling the software.... Connect the cable only when the printer software installation wizard suggestes to connect the printer to the system...
Jan 18, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printer is online and says ready but won't even attempt to print
Click on Start,
Go to Control Panel,
open Printer and Faxes
look for the Printer which is HP C5280 or any icon related to same,
Right click
Choose set as default
Close Everything
Shutdown your computer and Printer
Check and make sure that the USB cable is connected propely
Restart the Printer first and then the computer,try Printing some thing.
if this doesnt resolve you issue then i would suggest you to uninstall the printer software and reinstall and update it from HP.com.
Please let me know about the resolution
Oct 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
There may be some conflict arised in Printer, and you need to reinstall it again:
Uninstall the HP Printer software by using the Add/Remove Programs tool in Control Panel. The HP software will includes:
By Printer Design Home
HP Print creator
HP assistance
HP Instant Delivery
HP Print Screen Utilities
HP Photo and Imaging software
2. Uninstall the printer driver from the device manager.
Please remove the USB Cable from your PC completely.
Restart your PC without connecting USB cable back to your PC.
Then install the HP printer software, when it ask to connect the printer, then only connect and power on.
Your PC will automatically accept this USB Hardware driver.
After doing above steps please reboot your PC finally and Printer
Visit the Official Web site of HP for your Printer driver and other useful information using this link:
HP Printer C6180
Let me know the result, so I can further investigate the problem.
Best of Luck & Have a Nice Day.
Ellin
Oct 03, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
120 people viewed this question
Seeker5211
Seeker5211
