Question about Sony KP-51WS500 51" Rear Projection Television
I have a 2003 Sony KP-51WS500 51 in rear projection TV. After about 10 minutes , I get horizontal white streaks at different levels across the screen. About 10 mos ago, I replaced the d board because the TV wouldn't turn on (power light blinked 9 times). TV had been working after the board replacement until a week ago. Any suggestions?
  • 10,594 Answers
Usually it happens when High Voltage thick-red wire coming from flyback transformer is not put properly in High Voltage Block. mean if that wire is lose in HV block, TV will show you white steaks in screen due to spark in HV block.
Make sure to put red thick wire in HV block correctly and you can check it by pulling it back slightly, if it gets lock in HV block, it wont pulled back.
Below image taken from service manual will help you in installation of that wire..
Thanks.
Posted on Sep 06, 2009
My tv picture seems ok, but there is blue, arching streaks running horizontally, and a blue outline around words on screen. What is wrong with my tv? Please help.
u have a bad convergence ic , if u have same soldering skill u can do this repair , but i would recoment u to hire a tv tech normal repair is about $250
Aug 26, 2010 | Sony KP-57WS500 57" Rear Projection...
Picture is very blue, especially in dark scenes.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 21, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
What can cause horizontal white lines in a projection television? The TV is about 10 years old, and I am told it may be the internal power source. Could that be true?
can you see a pix or is it all white with lines running diagnally about every 1.5 inches--if you do not have a pix only lines problem is the 200 volt line feeding the crts(off flyback transfofmer)
Sep 02, 2009 | Sony KP-61XBR300 61" Rear Projection...
Sony rear projector TV problem, KP-61v35
This is a problem with the vertical circuit. This can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Let me know if you wish to attempt the repair and I will supply additional details and instructions.
Dan
Feb 26, 2009 | Sony KP-61V35 61 in. Rear Projection...
Sony KP-51HW40 51 in. Rear Projection Horizontal lines
Don't waste your time - go out and get another TV. Chaulk it up to that we have all been scamed by SONY. They knew about the problem, did not choose to make things right. They have become the Fat Cat with the attitude that no one can hurt them. We need to show them that they are wrong and boycot their products. That is the only recourse we have.
Nov 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Red shadows and mild distortion
Hi, relasmith did you ever fix your tv kp-57ws510
thank you
Apr 03, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp-46wt500 problem with picture
i'm having a problem keeping the timer from going off and shutting the whole tv off.
Mar 20, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Green lines on my Sony projection
Those are called retrace lines and they are the result of the blanking pulse not having the desired effect. This could denote a problem in the Horizontal section of the TV. In this case the green gun is not being turned off as it goes back to the left side of the screen.
Sep 20, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
116 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
