Question about Saws
I hear nose in the motor like it want to turn but it wont its a dremel scroll saw 1680 what would a motor cost and where tro take it to fix .Texas
  • 2,176 Answers
Go to Dremel.com and they have a toll free number that you can call and also look at a break down for this tool, they will be able to help you with this problem. If I have helped youu with your question would you please rate this response accordingly. Thank you
Posted on Sep 07, 2009
Testimonial: "Thanks I will do that."
HOW DO I OIL THE DREMEL 1830 SCROLL SAW?
  • page 15 Squirt a generous amount of SAE 20 oil around the shaft end and bronze bearing
  • Dremel 1830 Manuals
Sep 16, 2014 | Dremel 1830 120V 18" Scroll Saw
I have a 1680 scrollsaw and no manual. Where is oiling required?
Lubrication
ARM BEARINGS
Lubricate the arm bearings with oil after 10 hours of use.
Re-oil after every 50 hours of use or whenever there is a
squeak coming from the bearings.
TO LUBRICATE
1. Turn saw on its side (Fig. 18).
2. Remove rubber plug to expose bronze bearing.
3. Squirt a generous amount of SAE 20 oil around the shaft
end and bronze bearing.
4. Let the oil soak in overnight in this condition.
5. Next day repeat the above procedure for the opposite
side of the saw.
You can get the manual on the link below. scrool down to product details to get it.
http://www.amazon.com/Dremel-1680-6-Horsepower-Benchtop-Variable/dp/B0000302YQ
Good Luck
Dec 04, 2010 | Dremel Owner Operator Manuals Moto Shop...
My scroll saw will not come on. There is power to
The motor is probably fine. Try taking the case apart and check for a loose connection to the motor.
Nov 25, 2009 | Skil 5.0 Amp Variable Speed...
Dremel scroll saw 1672 16'' two speed scroll saw slow motor
Go to Dremel.com or call toll free1-800-437-3635 and tech service might be able to get you a schematic and wiring diagram. It does sound as though the switch is either wired incorrectly or put in upside down. If I have helped you on this would you please take the time to rate me accordingly and Thank you
Apr 03, 2009 | Saws
My DREMEL 1680 Variable speed 16" scroll saw will not turn on.
As a result of the power being on to the attached light I knew it was not a power source problem so I took the fuse area cover off(with the machine unplugged) and saw there were no loose connections in that area. I then removed the front control area where the two swithes for the saw and light were. I took off the two wires on the saw switch and then plugged the saw in and jumped the two wires together. The saw worked!!!!!!. I then changed the light switch over to the saw switch location and the switch works . It appears it was a faulty switch. Today I will call the Dremel 1-800- number and order a new switch.
Bernie Lutes
Dec 28, 2008 | Saws
Changing blade on Dremel scroll saw
I would suggest calling Dremel direct at 1-800-437-3635 and asking for tech help. You might also try their website at Dremel.com, but I have been there and you need to know the exact model number. Let me know and I will dig deeper.
Oct 22, 2008 | Dremel 16472 Carbide Coated Scroll Saw...
Saws Logo
74 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
