Rust spots on cutlerey
Rust spots
    Brigadier General:
  • 4,088 Answers
Rust spots on cutlery, but not on other dishes? It may be the blades are high carbon steel and not stainless. If so, then wash them by hand and dry with a towel.
Posted on Sep 06, 2009
I have faberware stainless steel knife set knives have rust spots. What & why??
How do remove rust spots from stainless steel Yahoo Answers
Yes, stainless will rust. The above link has helpful information on how to treat rust spots on stainless. The web site suggests using a mild acid, such as oxalic acid, which can be purchased at Home Depot or Lowes. Use a green scrub pad, as recommended. Hope this helps....
Apr 28, 2014 | Refrigerators
Rust in barrel
Clean area of rust and sand edges of enamel around spot. Apply rust reformer to area, and when dry, apply a coat of J-B weld to overlap the edges. Auto parts stores have these items, about $10 total.
Nov 29, 2013 | Kenmore 62602 Electric Dryer
The microwave oven coating is peeling and exposing rust spots. what can I do to fix this? Do I need a professional repair person?
No this is something you can repair yourself. Take sandpaper and gently rub rust spots until smooth. Then you need to get ceramic touch-up paint and repaint rust spots.
Feb 09, 2011 | GE JX2030DMBB Optional 30" BuiltIn Kit ...
I have rust spots/stains in my bathroom door frame which is alongside my showerwater appears to be getting into the door frame (aluminium not wood) and staining the paint its rust spots so i know its...
aluminium does not rust so the stain will not be rust stains
could be leaking fitting at the plumbing pipes at the taps
could be that the washer under the tap insert is leaking especially if not replaced when doing the spindle seals
May 03, 2017 | Washing Machines
Rust spots on bottom rack
You may need to replace the rack. Dishwasher soap is aggressive and once an area is exposed, it will rust fast. Make sure you don't place sharp objects in direct contact with a rack. The action inside the washer can cause them to move and rub through the metal rack coating.
Dec 06, 2009 | Maytag MDB6650A Built-in Dishwasher
Rust Problem
that is not the cause of the brown spots, the front or rear felt is worn out, i've seen the rusty inlet and output for 19 yrs and never saw that cause brown spots yet, your clothes will never come into contact with the holes long enough to cause a spot!
Nov 16, 2009 | Kenmore 73952 Gas Dryer
My microwave oven has are rust spots;can I paint over them?
Yes, you can paint over the spots and no, it's not dangerous. I'd let the paint thoroughly dry before using the oven -- it could otherwise cause paint to buckle/ripple/etc.
May 03, 2009 | Microwave Ovens
Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
paint ain't perfect!
rust on a 15yr old appliance is normal
Dec 01, 2008 | Refrigerators
RUST SPOTS
My 10 year old Kenmore (Whirlpool) top load washer is rusting under the top cover. The entire cover from the bleach dispenser all around is rusted under the lid. Periodically, rust dislodges into the tub and stains whites. You would have to treat the rust under the lid. I decided to try, using "Rust-mort" rust treatment on a rag. The rust would all have to be wetted with the rustmort after some scrubbing with a scuff pad. I have not attempted this yet.
I went to OSH and checked lids on new top load washers. The lip on the cheaper models was not properly coated with paint, and I could feel the rough partially exposed metal, which would rust. The more expensive models had a smooth well coated lip on the underside of the cover. Hope this helps.
Oct 22, 2008 | Washing Machines
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
