Question about Acer Aspire 7720-6569 Notebook
Cursor will move to another part of the screen-no apparent reason
It happens in all programs. Can I do anything to keep the cursor where it should be?
    Scholar:
  • 141 Answers
This is often caused by the "joystick" in the middle of the keyboard or the touchpad. If you can disable them individually in the control panel and use an external mouse, you may be able to narrow down the situation. Cleaning the touchpad and blowing out the keyboard around the joystick may clear it up.
Posted on Sep 06, 2009
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Aug 01, 2010 | Sylvania G-Netbook
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
Laptop cursor jumps around, turns crosshair, screeturns black
windows vista is probably the problem...have you tried running a virus scan? McCaffe...could actually have one from the factory
Oct 05, 2009 | Acer NSK8458AN Keyboard
Cannot double click......
U first uninstall ur touchpad driver and then restart ur laptop and then install ur touch pad driver. If it is not working then check out Folder Options in Control Panel
Aug 03, 2009 | Acer Aspire 5610-4648 Notebook
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Erratic Cursor Behavior
Are you sure your not touching the pad as you type , a common error, cover the pad with card board or plastic and see.
otherwise you may have a bad touchpad and it needs replaced or re-seated on the cable.
Mar 22, 2008 | Computers & Internet
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Acer Aspire 7720-6569 Notebook Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
