Question about Radio Shack Pro-2055 Base Scanner
Can not get channels programmed - Radio Shack Pro-2055 Base Scanner
    Problem Solver:
  • 10 Answers
I would need to know more about your problem before i can advise you.
Posted on Sep 09, 2009
On my jvc tv model hd-61g787 I cannot program channels
you can program channel either in the remote control or in the tv button panel. press menu then go to manual fine tune so you can program the channel one by one. you can use the volume up/down button to tuned the desired channel. to select channel use the channel up/down button.
Jun 01, 2013 | Televison & Video
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
PROGRAM AFTER ALL LOCKOUT OF ALL CHANNELS ON A BC60XLT-1 SCANNER
With the channel display showing 000.0000 you may be able to program a new frequency into it, and the new program will release the lockout. Have you tried the normal programming for any channels?
Bill B
Apr 08, 2010 | Uniden BC60XLT-1 Handheld Scanner
I have a uniden bearcat portable and base I cant figure out how to program it
With the scanner powered ON,
1. Press [HOLD].
“HOLD” appears on the
display.
2. Press [PROG]. CH appears
and blinks to indicate that you
are in the Programming Mode.
To change the displayed frequency,
use [UP] or [DOWN]
while “CH” is blinking.
3. Press [PRIVATE]. “PRIVATE”
appears on the display.
If you want to program it into
another bank, press the
desired bank key. The lowest
open channel appears on the
display.
2 screens alternate to indicate
that open channel is available
to be programmed.
The scanner automatically
selects the lowest open
channel (000.0000) for easy
programming. If all channels
have been programmed (there
are no open channels in the
bank), channel 1 appears.
Use [UP] or [DOWN] to select
a new channel and even overwrite
old channels.
4. Press [PROG] to store the
frequency in the desired
channel.
Note: Press [BAND] to escape
from programming mode before
step 4.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Oct 01, 2009 | Uniden BC350 Base Scanner
Timed recording with cable (new)
If you're referring to programming your VCR for recording, that works just like it did before the cable box was installed, but with two major differences.
The first difference is that the VCR must always be programmed to record on the converter box output channel. Usually this is channel 3, but may also be channel 4. The cable box selects the channel from the cable system, but it's always outputting to your TV on the same channel. That channel is what the VCR needs to record from.
The second change to programmed recording is that you can't program your VCR to record programs on different channels. The reason is because, as mentioned above, the VCR is actually recording from the cable box which is always on the same output channel. Unless you are home to change the channel on the box, you're stuck. For example, if you want to record a show at 10PM on channel 8 and another at 11 on channel 26, those are the cable channel numbers. The box output is channel 3 (or 4) in both cases. The VCR can't switch the box for you. It's only going to record the program on the channel you selected before you left home. You also need to leave the cable box turned on, but the TV can be off. This is probably the thing most people find confusing about dealing with a cable box.
Now having said all that, some brands of cable box do include a timer feature of their own that allows you to program the box to switch channels. This feature is used in conjunction with timer recording on the VCR. You still always program the VCR to record on channel 3 (4), but now the box can be programmed as well to switch to the channel on the system you want to record. This allows you to get around the limitation described above. If your box offers this feature, it will be accessed through its setup menu using the remote control. Ask your cable company if this is available if it's not clear from the setup menus or instructions the installer left you with.
May 12, 2009 | Emerson Televison & Video
Channel Program/Setup
I have the same problem. Try to programa de ic u201v with the original program.
good look
Aug 05, 2008 | GE 27GT271 TV
Uniden/bearcat BC-100
If it's indeed a BC-100 and not a BC-100xlt, the 16 channels are easy to program and use.
1. Press MANUAL 3 MANUAL with 3 being the number of the channel you wish to program.
2. Enter the frequency for that channel (e.g., 162.55) followed by ENTER.
3. Follow the same sequence for each channel you wish to program, except that pressing MANUAL after you program a channel will advance the scanner to the next channel.
To scan, simply press the SCAN button after your frequencies are programmed.
Bill B.
San Antonio
Jul 15, 2008 | Uniden BC248CLT Base Scanner
Constant tone on an HT1000
You will get a constant tone on any channel that isn't programmed. it sounds like the previous user ha a freq programmed on channel 1. Channel 11 is strange, but possible. Usually guys program these radios in order.... they don't put 2 freqs in soo far apart from each other..... I would expect channel 1 AND 2 to have freq programmed in them.... but channel 1 an channel 11 is strange... but possible. Anytime you don't fill up all the channels on these radios (commercial radios in general) you will get a constant tone on the channels that don't have anything programmed in them. Program the radio and your good to go. If you don't program freqs into al the available channels, expect to hear that "constant tone" on any unprogrammed channels. The channels that you hear a tone on do not have a freq programmed into it. Its normal. Good luck
Jul 05, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
CHANGING FROM FREQUENCY TO CHANNEL MIDLAND 75-822
Some models of the 75-822 do not offer this as a feature. Instructions for it are not included in the manual. I recently encountered a refurbished model packed with a manual such as this. Pressing and holding the "F" button toggles between Channel number and Frequency number display.
Jun 17, 2007 | Midland 75-822 40-Channels Handheld CB...
Radio Shack Pro-2055 Base Scanner Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
