Question about Akai LCT2715 27 in. LCD Television
AKAI LCT2715 will not turn on gives blinking
AKAI LCT2715 will not turn on gives blinking yellow, orange light and speakers pop
    Problem Solver:
  • 12 Answers
This series of TVs has a famous issue with the power board (part number MLT166A or similar). Several capacitors and zener diodes burn out causing some resistors to burn as well. If you are capable of doing component level repairs check capacitors on the board and zeners Z2, Z3, Z4, Z5 and resistors around them. If you prefer to spend hundred bucks and simply buy the working power board for it - ebay is your answer.
Posted on Sep 06, 2009
Akai lct27.
Can anyone please tell me the voltage of the zener diode z3 in the power supply.
Thanks.
Posted on Sep 07, 2009
  • crashdogy May 04, 2011
    Just want to say thanks had my AKAI TV siting around for about 2 years and now it’s working Yahoooooo
The power light is constantly blinking in yellow. before this happened the yellow light was on without blinking I turned it off, once I turned it back on the light turned green but the screen...
try unplugging your t.v for 10-20 seconds. plug it back in. if your power light continues to flash your t.v is the issue. you should be able to google your issue or check your owners manual about the problem. unplugging the t.v is the last ditch effort. Good Luck!
May 18, 2011 | Akai LCT2715 27 in. LCD Television
Akai TV wont turn on right
this could be the power supply board
May 13, 2010 | Akai LCT2715 27 in. LCD Television
My television blinks yellow light
i have same tv lct2715 my customer gave to me.
open back cover you will see many many bulging capacitors that is 1000uF and 470uF at powersupply and mainboard . replace all!
mine works great!
Aug 11, 2009 | Akai LCT2715 27 in. LCD Television
Orange flashing light
To all akai LCT2715owner power problem?check powersupply and mainboard. do u see any bulging capacitors that is 1000uF and 470uF? yes? replace all!
Aug 10, 2009 | Akai LCT2715 27 in. LCD Television
27 akai lct2715 POWER SUPPLY
Have you had your power supply repaired? If not i can possibly help you with this issue.
Nov 07, 2008 | Akai LCT2715 27 in. LCD Television
AKAI LCT2715
Its busted. Try resetting it as a last resort, unplug the AC, wait 1 minute, then plug back in. If that doesn't work, its in need of professional service.
Jul 31, 2008 | Akai LCT2715 27 in. LCD Television
Akai LCT2716 Flat Panel TV
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
Mar 12, 2008 | Akai LCT2715 27 in. LCD Television
AKAI LCT2715
I replaced 19 filter caps in LV power supply.
There were pruffed up on top
Mar 11, 2008 | Televison & Video
Power light blinks red - tv will not come on
to let you all know that Im having the same problem with my tv.. amber then red red red red... and popping sounds from speakers... Its because they use cheap parts there are 19 capacitors in the power supply (DONT RECOMMEND FOR NON EXPERIENCED PEOPLE) the 2 main filter capacitors are 100uf450v the ones in mine are just fine then there are 3x 1000uf16v, 2x 470uf16v, 3x 470uf25v, 2x 1000uf25v, 6x 1000uf35v, and 1x 470uf35v... Im in the process of replacing those capacitors. about half of them are leaking and 1 is blown... very dangerous for anyone messing around back there.. just thought i would let everyone know that its a 20 dollar repair if you know what you are doing i got my caps at marvac.com
any other questions email pfctmitsubishi@yahoo.com
Dec 04, 2007 | Akai LCT2715 27 in. LCD Television
Akai LCT2715 Led blinking orange and set won't turn on
There are about 16 to 17 capacitors that are a common fail point on this TV. I can repair your power supply board with new high quality capacitors and recondition the board to work like new for $100 + S/H, you simply have to send me the power supply module and turn around is approx 2 days from the time I receive the package to the time its out the door. Approx 8 business days according to the delivery carrier you use.
Apr 09, 2007 | Akai LCT2716 27 in. LCD Television
Akai LCT2715 27 in. LCD Television Logo
816 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
