Alighn ariel for digital tv
I have just bought a digital tv for my caravan and played about with a tv ariel and pole and got it working my question is i have a satalight finder meter can i use this to alighn my ariel or is there something i can get to help alighn my ariel and any tips on ariels for digital
  • anth1 Sep 07, 2009
    thanks for that thats the way i set it up by looking at others and pointing the same way took a bit of fiddling to get it exact. i dont think my meter is a spectrum analizer just a buzzer and needle point the dish and when the needle is at the highest stop there must be something like this for ariels i paid about £10 off ebay for works great just dont know if it will work for ariels point and hope takes time
  • 458 Answers
The best type of aerial for digital reception is to use a wideband aerial this will give you a better spectrum to receive the signal. To locate the aerial position, if you know in which direction your local transmitter is situated, then point the aerial in that direction. The best way to find out which way to point is to simply look around at any of your neighbours aerials & then aligned yours in the same direction. If you are using a spectrum analyser as your sattelitte finder then you can use this to find other frequencies in the signal range.
Posted on Sep 06, 2009
What is aerial located on my box
Ariel is where your cable input is coming in from a trunk/feeder line from the pole or a simple coax line.
Sep 26, 2014 | Digi Sansonic FT-300A tal To Analog TV...
Tv has no signal
The TV you are trying to connect to may be an older type and not a DIGITAL receiver. The old ANALOG type no longer work with the Digital applications unless to have a CONVERTER BOX.
Dec 22, 2013 | Televison & Video
I fitted a Peak dvb-t digital tv usb stick with an ariel included and it doesnt pick up any channels. if i fit an internal tv card will that work instead please?
IN GENERAL these decives don't have decent reception when working in side and with the internal ariel. If you can use an external roof fitted ariel you will get better recpetion. I even had a dedicated portable tv that didn't receive all channels, in France, due to the inferior internal antenna.
Jul 05, 2011 | Computers & Internet
The antenna/cable connector looks broken. can this be replaced?
Hello
In most models of Sharp Telivisions,antena socket is an integrated part of the tuner itself and cannot be replaced with an other one. There is only one way and is to replace the tuner itself.
If you don't mind of style, you can solder two wires, one from the center pole of the antenna socket, and other from it outer rim, and take it out and connect to an external ariel socket [can be bought from electronic sparepart shop as a seperate socket] , to whcih you can connect your ariel pin. It will look a little dull, but you can face the probelm, without replacing the tuner. When making these connections, use sigle cored shield wire. It center wire must connect to the center pole of the broken tuner socket. OK.
Dec 09, 2010 | Sharp 27N-S300 TV
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
I cannot find my tv ariel hole to plug my ariel in
It's not a TV but a monitor. You need an external tuner such as a satellite or freeview (in the UK) box to drive it
Jun 29, 2009 | LG Televison & Video
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
Loss of Freeview channels
They are probably engineers working on your local digital transmitter or the wind has moved your ariel slightly.
This message is always to do with signal and is not a fault with the tv.
Nov 13, 2007 | Televison & Video
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
