Question about Cub Cadet Street Sign- tractor lawn riding mower parts
HYDRO DRIVE SLIPPING CUB CADET 2135
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
SOURCE: My Cub Cadet 2135 PTO won't engage.
i had the same thing happen
found that the on/off switch had come unplugged from the wire harness just below the switch
had to attach the wires to something underneath so the weight did not pull the wires down and taped the two switches together to prevent it from pulling apart
it needs some kind of clip to hold them together
hope that this works for you
jo
Posted on May 24, 2009
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
  • 10865 Answers
SOURCE: i have a cub cadet lt 1050 need diagram for drive
Hi. All of these questions are answered in the owner manual. TO download one go to this link http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10051&langId=-1
J.
Posted on Aug 03, 2010
Going to try this again, cub cadet rider mower leaking oil into air filter compartment, it's a 2135 with a 13 HP Command OHV motor
Sounds like a crankcase ventilator is plugged up. It serves the same purpose as a pcv valve on automobile.
May 22, 2017 | Cub Cadet Garden
I need to know how to install drive belt on cub cadet that has hydro drive with diagram
That will depend on the model of your mower. Generally you have to remove the deck and deck belts. The drive belt usually goes from the engine pulley to the transaxle pulley. There may be a tensioner pulley as well that keeps the belt tight.
Jul 11, 2016 | Cub Cadet Garden
My 1500 series cub cadet 42" mower with hydro transmission runs good but mowes very slow. What could be the problem?
Is the tractor moving slow or are the blades moving slowly? The belt on the mower blades may be slipping. If the tractor is moving slowly look to see if the transmission needs fluid.
Aug 08, 2015 | Cub Cadet Garden
Cub Cadet,model 2135. Is there a relay betwee switch and electric pto?
a short on the hydro wire have to find chase the wires from pto back if you dont find it take it in because if you dont you will burn up the stater
Sep 19, 2014 | Cub Cadet Garden
I have a LT1042 hdrostatic drive and it won't go forward or reverse what is wrong
can only guess
Low on cub cadet hydro fluid?
other hydro filter other and cub cadet?
linkage came unhooked from drive mechanism
your engage disengage lever at the back of the mower is set so it can be pushed,engage lever to allow hydro pump not to be bypassed
Jul 28, 2014 | Cub Cadet Garden
Cub Cadet 129- The drive shaft from the engine to the hydrostatic drive does not line up at the hydro end. What should I do? The roll pin in the shaft at the engine hub it connects to kept shearing, and...
This mis alignment of 1/4" is about normal that is how and why cub put the rubber flex coupling on the hydro... however if there is play in the hyro input shaft then we need to determine what the cause of this is. Good luck
Sep 07, 2009 | Cub Cadet Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
111 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
