Question about HP Computers & Internet
Pocket PC 2003 Pro unable to align screen
I have a Pocket PC 2003 Pro, after numerous attempts at: hard resets and letting the battery completely drain, the furthest that I can get after each attempt is the Windows Mobile "Tap the screen to set up your Pocket PC". I tap the screen and nothing happens. I can push the pause button on the bottom of the Pocket PC to take me to the "align screen" but still nothing happens. Any suggestions would be greatly appreciated.
    Problem Solver:
  • 18 Answers
Start your phone go to start navigate to options/ control panel then touch sceen using the d-pad then click align screen then use your stylus to adjust the screen.
hope this helps -RJ
Posted on Dec 20, 2009
  • 1,889 Answers
The touch screen plug on the motherboard is disconnected
Posted on Sep 06, 2009
My micromax x600 mobile asking input phone lock code
visit www.hard-reset.com or see the result.Hard reset
Cold boot method: Hold the "Power Button" of the Pocket PC with one
hand while holding the stylus tip to push in the "Reset Button" with the
other. Simultaneously release both the "Power Button" and "Reset Button".
Appropriate situation: If a previous reset has already been attempted and
the Pocket PC is still unable to maintain normal operations, has no
response, or if the screen is frozen.
Before executing the preceding "Cold boot method", please carefully
consider the following instructions and then decide on the cold boot
method.
1. After a cold boot is performed, if no buttons are pressed, when Pocket PC automatically completes the system startup process, the last display will be the Today screen. This is identical to the reset result.
2. If a previous reset has already been attempted but the Pocket PC is still unable to maintain normal operation, consider the following solution:
After cold boot, hold the End Button eten_glofiish_x600_hard_reset_soft_reset_5.jpg on the bottom right of Pocket
PC until the system inquiry screen is shown, and then release the End
Button. Next, please read thoroughly through the instructions on cold
booting before continuing carefully.
Erase all data and load default?
The default is "No." If Yes or No was not
selected, after a few seconds the system will
automatically execute the default No.
If you long press Left Soft-Key for a few
seconds to select "Yes," then the system will
erase all data and load default. After your
Pocket PC restarts, follow the instructions on
the screen to complete.
Caution!
1. After performing a cold boot, the system will retain Microsoft Windows
and pre-installed programs. If you answer "Yes" to the question displayed
after a cold boot, other items such as the user's input data, newly installed programs and user settings will be lost.
2. There are two ways to retain your data, loaded default and registry:
Perform a Reset.
Performing a Cold Boot, and answer "No" when the above question
displays.
Jun 27, 2012 | Eten E-Ten GloFiish X600
Model 2003 ipaq, can't get past alignment screen
try a hard reset(hold down the 2 outside corner buttons,calender and home, then use the stylus and press the button on the back). if this does not help, go to HP support site and get the latest ROM update, download and install. this will completly set device back to factory settings, your sync folder will still have all contact, pics, appmt.,etc. hope this helps.
Jan 17, 2010 | Microsoft Windows Mobile 2003 for Pocket...
I have an imate pda2k pocket pc and is working good. Out of curiosity i tried hard reset and it ends to align screen. Everytime i made a hard reset the screen show " tap the screen to setup your pocket pc"...
tap and hold on align target until it moves to next corner or next step, if you are using windows 6 or 6.5 you should be very much accurate on taping and holding to align the screen.
Nov 01, 2009 | i-mate PDA2k Pocket PC
Screen align problem
try to do hard reset if its not works
try to update rom image
if still not works try to replace your touch screen to new one
Dec 15, 2008 | HP iPAQ H3950 Pocket PC
Imate pda2k pocket pc shows align screen
go to start, setup, system, screen, and then click align screen. and then it will give u some small circles to tap on it. u tap correctly on the circles. after few clicks it will automatically tell u that ur screen has been aligned. ur problem is solve by a cute pakistani. pakistan live long. love u.
Oct 06, 2008 | i-mate PDA2k Pocket PC
Screen not responding to stylus
SOLUTION:
KEEP PRESING CALENDAR+MAIL+POWER BUTTON
AND INSERT STYLUS IN RESET BUTTON
Nov 26, 2007 | HP iPAQ H1940 Pocket PC
Frozen screen
hello :-) i just talked to another person who was having the same problem as you. And guess what?? the same problem happened to me on my IPAQ 4350. It turned out when I would hard reset my IPAQ it asked me to align the screen but it wouldn't move and it would freeze and not let me pass . But I later found out that my screen was damaged and I got a new touch screen installed and my IPAQ works perfect :-). I would recommend for you to do the same and call HP and see if they could install it for you. Thanks :-}
Nov 05, 2007 | HP iPAQ H2210 Pocket PC
K jam screen align does not work after hundred or so attempts
Well, folks i had the same problem with the damn i-mate K-JAM model but i have figured out its solution. Well screen alignment options will always come on ever reset whether it is hard or normal and further more it would be nail biting for most of us because it doesn't work at all. It seems like some sort of a bug either in Windows Pock PC edition or HTC manufacturing bug. Whatever u call it only we would be the victim of it. Here is the solution.
When the alignment screen comes Just Tag the {+} << in the exact centre it will then move to the top let corner of the screen again tag it from the middle and it will then jump to the lower left corner now don't tag it from the middle instead tag the lower left corner of the screen. It will then move to lower right corner of the screen now tag it again in the middle and finally it will fly to the top right corner now again instead of clicking in the middle just hit the top most right corner of the screen and now u r done. Screen is finally aligned whoops!
Sometimes even when the screen is aligned the touch pad malfunctions if this is the case with you u need to update the firmware like i did just search through Google the i-mate k-jam windows Pocket edition update.
Thanks
Jun 25, 2007 | i-mate K-jam Smartphone
Hard reset does not wok in my ipaq H3955
The touchscreen may be broken, try hardreset again if it doesn't help contact your dealer or HP for possible repairs.
Sep 14, 2006 | Compaq iPAQ H3955 Pocket PC
Computers & Internet Logo
111 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
