Question about Crosley CDE6000 Electric Dryer
Dryer has power and timer is working but wont run.
How do you remove fuse and check if bad or could it be a bad door switch
  • jagular Feb 17, 2008
    The Dryer will not start, but the timer switch still hums like it is working. I tried bypassing the doorswitch, but still does not run.
  • Anonymous Aug 23, 2008
    dryer wont run
  • 550 Answers
Rcurrier
most common cause is burn out of the thermal cut-out. These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
Clean the exhaust ducts all the way to the outside wall, lots of vent hoods block over time. then examin the exhaust duct for devices that look like this Dryer has power and timer is working but wont run. - 16b0719.jpg or like this b295dc6.jpg with wires connected to the terminals. there may be 2(hi lo), test with a flashlilight bulb or meter conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
It has power but wont run.i can hear the timer on iy.
It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a Kenmore dryer there is a tab that sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Jun 10, 2010 | Dryers
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
Dryer will not come on at all. working fine on last load
check house fuse/circuit breaker
door switch
if an electric dryer the thermal fuse as they are often wired into the motor run circuit
check for power to the motor in start and run circuit, if present motors spent.
if not present trace back to timer and verify timer is sending power, if not timers spent.
more likely circuit breaker, door switch or thermal fuse if electric dryer..
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Kenmore 64902 Electric Dryer
Dryer timer works but start button doesn't and wont turn on
I would check the door switch. If it's bad, the dryer will not run. You can check it by taking the two wires going to it and tying them together. Be sure to tape them together so they will not touch metal and short. If the dryer runs, replace switch. If not you most likely have a bad thermal fuse and or thermal cut off.
Oct 12, 2009 | Kenmore Dryers
The timer is running but the dryer will not come
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Oct 03, 2009 | Dryers
Dryer will not start, has power to unit,timer seems to be working....door closes and locks as it should...
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 16, 2009 | Dryers
Dryer wont start
First I would check the door switch I could have broken off or quit working if that is ok then there is a white thermal fuse on the blower housing behind the back panel check with a ohms meter to see if it is good it has two wires going to it
Mar 30, 2009 | Maytag Dryers
Power button wont start dryer
check the door switch,also you can remove the back panel and check the little white main fuse on the blower box-mike
Mar 21, 2009 | Whirlpool LER4634J Electric Dryer
Crosley CDE6000 Electric Dryer Logo
99 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
