Question about HP Pavilion TX2000Z Notebook
Hp pavilion tx2000 screen stays black after power up
Lights are on and I can hear the fan running
    Problem Solver:
  • 12 Answers
There are several things that can cause this. Basically your laptop freezes during POST (power on self test). This happens when one or several hardware components do not pass through the test. It can be RAM, processor, motherboard. Not so likely but still possible because of a failing hdd, cd drive or even touch pad (I had this once on a Toshiba A45 laptop). So if this laptop is still under warranty it is definitely the case when manufacturer should fix the issue. If it is not under warranty it would be hard to determine the problem without testing your system and each of its components.
Posted on Sep 06, 2009
Screen stays black when I turn it on
My point of view RAM section direct connect to display so first you check RAM.Then check processor Fan proper working or not. and finally power connection in screen.
Thanks..
May 08, 2013 | HP Pavilion ze4935wm PC Notebook
HP a6500f will not come on...no HP Logo...no beeps...black screen...fans run
if u have system mechanic, you can use the disc to boot from and it'll read your MBR....it is probably messed up....and needs to be repaired. Have you ever used a registry cleaner? if not, you also may have tons of registry errors....and registry errors can also give you blk screen of death.if you have no system mechnic disc nor can borrow one, then try this.....http://download.cnet.com/MbrFix/3000-2094_4-10485990.html?tag=mncol;1
please post back you findings
Apr 22, 2012 | HP KQ495AA Pavilion A6500F Desktop PC
HP tx2000 - black screen.
Hi
The problem you are experiencing is related to the screen of your Hp.
All you need to do is to is to get to a computer store and get your screen replaced.
You can not fix a damaged screen.
GOOD LUCK
Jun 17, 2010 | HP Pavilion TX2000Z Notebook
My cooling fan has stopped working - laptop is a hp pavilion, model tx2000
If you unplug the fan, you can test the connector to make sure the fan is bad and the problem isn't with the power getting to the fan.
You can get a new fan and heat sink assembly here (make sure the model number is the same as your computer):
http://www.sparepartswarehouse.com/HP,Pavilion,tx2000,KX531AV,Laptop,Fans.aspx
But in the meantime, you shouldn't run the computer much because it can easily overheat without the fan.
Jun 06, 2010 | HP Pavilion TX2000Z Notebook
I have to turn it on and off for several times just for it to start wroking
If you get just a black screen - all lights on except hard drive light and fan seems to be working, then you are probably experiencing the same GPU (video chip) issues as others. Here is a good read - http://h30434.www3.hp.com/t5/TX-series-notebooks/Familiar-Story-tx2000-lights-and-fan-on-but-black-screen-at-boot/td-p/87361
...and here is the service manual if interested in trying the permanent fix yourself.
Jan 09, 2010 | HP Pavilion TX2000Z Notebook
My BOSS HP tx2000 will not turn on WHILE...
ok Do you hear any soun when your system try to boot?like a beep sound ?
try this remove battert remove the ac adaptor from the noatbookand press and hold the power button for 10 sec and connec the ac adapter not the battery and turn on the noatbook and at the HP logo hit the F 10 key for 2 times and you will be on bios screen hit the F9 ket and restore the setting to default and hit F10 agian to save and exit and allow it to boot it thats work try with battery connected
Regard!
Sep 16, 2009 | HP Pavilion TX2000Z Notebook
Hp Pavilion Dv600 Wont start up!!!
it looks like your mainboard is cutting the power. and need to get servvice.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
HP Pavilion TX2000Z Notebook Logo
258 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
