Question about Acer Aspire 5500 5570-2609 Laptop
Trouble connecting to wireless hub
Setting up a new acer laptop it wont let us connect to wireless hub even though signal is strong
    Problem Solver:
  • 11 Answers
The wireless router you have may need to be configured to your laptop.Call the router manufacturers customer service and they should be able to tell you what to do to get it to work.
Posted on Sep 06, 2009
I have an acer extensa 5620z and netgear dg834v5 modem/router. I can connect via ethernet, but even though i have set the router without security, the laptop detects the wireless network, but won't...
This is worked for me on Vista:
1. Goto Network and Sharing Center.
2. Click on your Wireless Connection "View Status".
3. Click on Propertes.
4. Uncheck the option that says "Internet Protocol Version 6"
When I did this, my wireless began working again.
Jun 11, 2011 | Acer Extensa 5620 Notebook PC
My laptop has suddenly stopped connecting to my home hub.it knows its there and tries to connect but 'times out' very very quickly. laptop identifies the hub and there is a strong signal just doesnt want...
Your router broadcasts your network SSID (network name) and that's what you should see in the "view other available networks" panel. If it's different to what you have set on your laptop, it's not going to connect. Also you must of course use the same WEP (network key) as all the other devices. Make certain the the IP's of all devices is set by DHCP, which is usually the default, but may have been changed.
Mar 25, 2010 | Acer Aspire 5500 5570-2609 Laptop
Bt home hub (shuny black one) wont connect wirelessly
Try to disable the netgear interface and let windows manage the wifi card. This could also be happening if the signal is not strong enough where the machines are.
Is your wifi hub also a netgear? If not it may not be compatible with the cards if that is the case you will need to replace them with diffrent make of the cards preferably the same brand as hub.
Jul 27, 2009 | NetGear WG311T 802.11g/b (wg311tge)...
Connects to network, strong signal, will not connect to internet.
it looks like wireless card in the laptops need to be changed.
Jun 03, 2009 | Acer Aspire 5610-4648 Notebook
Wireless failure
Power down your wireless router for a couple of minutes, power it up again until all the LEDS indicate that it is up and running, then power up your laptop. Then see if can get on the Internet.
If you don't get into the Internet get back to me with any error messages and I will advise you what to d next.
Mar 25, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 7730 UNABLE TO GET WIRELESS CONNECTIVITY
you need to try
1) check bios aetup screen thereis setting wireless enable/disable
and check xp control panel--system--device manager wireless driver no yellow triangle mark( which need update driver)
2) check wireless switch at laptop frront or right side, set to "on" to make sure the wireless light not on. if wireless indicate light still black means your wireless card out of works, check wireless card by open small back cover clean pins and reinstall it again
3) finally you might need change a wireless card.
Feb 06, 2009 | Acer Computers & Internet
Internet connection
What sort of modem/router are you using. I had a problem with a DLink which required an updated bios to stop it from turning off the wireless connection even though all the settings said it was to be always on.
Feb 04, 2009 | Computers & Internet
Dropped Wireless connection on Aspire One 8.9" Netbook
make sure your isp is suppling your 2nd ip address...
Dec 25, 2008 | Acer Aspire One Netbook 8.9" Notebook
Wireless Connection limited range and intermittent
1. Access the router's setup page then go to wireless tab and change the current wireless channel to a different one.
2. You may also upgrade the firmware of your router.
Nov 08, 2008 | Linksys WRT300N Wireless Router
Settings in laptop for wireless connection
Most of the time the encryption key is typed wrong. make sure that yours is correct.
Dec 31, 2007 | Acer Aspire 5630 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
