How does knowing the freezing point of water save lifes?
I need to know how knowing the freezing point of water can save lifes. Please give a referance.
  • 534 Answers
By lowering the body's temp at time of injury it prevents cell damage to major organs ( in the event of a heart attack the temp is very important due to the amount of cell damage that occurs in such a short amount of time) Persons have drown in 33 f water being submerged for 5 minutes or longer and are revived due to the body's temp drop there isn't much damage done to the brain because of the lesser amount of brain cell damage due to temp The colder the body the longer time is allowed for revival. Check info on cyrogenics for a better idea of the reson the temp is important Hope I didn't confuse you with this explaination
Dave
Posted on Sep 16, 2009
Need to know steps to winterize a 2001 Thor-Citation 23-R trailer. Or schematics of key points to address.
If you don't have a hot water heater winterizing bypass kit installed,get one before going any further.
Next, drain the water out of the hot water tank. Add POTABLE (not automotive) anti freeze to the water system Run run faucets one at a time both hot and cold, toilet and shower head until you see the anti freeze . Next, shut off the water pump and open the faucets. This saves any chance of cracked water lines. When you want to use the trailer again, close the bypass valves on the hot eater tank and run the pump long enough to remove the antifreeze solution from the system. Fill the water tank and run the faucets for a few minutes. Potable antifreeze won't make you sick so there's no worry if you don't get it all out of the system.
Nov 02, 2014 | RVs
The tank takes forever to fill. By this I mean 2+ minutes which is too long.
I'm going to help in one way, after your done using the bathtub, don't let it go, let it in the *******, I mean save the water to flush the toilet or water the plants, to save more water, it work in my family
Aug 17, 2012 | Plumbing
Ice maker not working
Try filling with tap water and allow water to freeze. Once the water freezes and ice dumps into ice bin and water does not refill this will point to the dual water control valve. On the Model FRS6R5ESB0 that part is a Triple Water Control Click Here=> 241734301 Water Inlet Valve I will be here should you have questions but for now please try the tap water fill test and let me know how that turns out, Thanks, Sea Breeze
Mar 20, 2012 | Frigidaire FRS6R5ESB
Free microsoft points
as much as i would love to give out illegal info on this sight i cant. and let me give you a tip.there is no such thing as free microsoft points. no matter what videos you watch and what you google, you will run into "point generator downloads" that do not work. When you download these, they come with some sort of a scam security system that will screw up your computer. Google "Pc optimizer pro scam and Hard drive diagnostic" before you download anything illegal and see if you want this on your computer. Think twice about it. ~I know this isnt the answer you wanted but i am just saving you weeks of frustration. I went through it, as has pretty much everybody on xbox live. Unless you are some sort of master hacker, witch takes years to accomplish, probably a hole life, you will not hack microsoft points. the security on xbox live is amazing. sorry for any disappointment,Elijah
Dec 18, 2011 | Video Game Consoles & Games
Ice maker (Kenmore model #57562792). When dispensing water into the tray the water will freeze in the shoot. Resently the water oveflowed out of the shoot freezing the water. It is like the sensor value...
Hi and thanks for choosing FixYa I am Kelly.
Ot took me a bit to sort out your model number started with 106 for a complete model number of
106.57562792.
You already more or less stated what the remedy is. in this starement:
It is like the sensor value does not know when to stop sending water to the tray
What happens during the life of refrigerator is the inlet water valve fails. This caused the ice in the water fill tube because it was a very slow drip so the wter froze in the tube. It also causes the ice tray to overfill because it is allowing water to bypass when it is supposed to be shut off. (Common problem after unit is 4 - 7 years old)
Your inlet water valve needs to be replaced PN: 2182106
Net search: 2182106
http://www.google.com/search?q=2182106&rls=com.microsoft:en-ph&oe=UTF-8&startIndex=&startPage=1&um=1&ie=UTF-8&tbo=u&tbm=shop&source=og&sa=N&hl=en&tab=wf
Sears parts direct lists it under your model number for $70.92. As you can see from the net search... you can get them MUCH cheaper.
When you change this inlet water valve... save yourself all the headaches... Change ONE line at a time and One connector at a time. Hook up the main water supply LAST.
This will fix your current problem.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Kenmore Side by Side Refrigerator
I am looking for a wire harness diagram for a optiway fortress 1704fs
Hello,i dont know what that is lol.but this site i will give ya is what it says :WWW.ALLDATASHEET.COM
Type in your product & download it to an Adobe Reader + print it & save to a polythene slweeve folder for future.please rate me as in thumbs up 1 to 4 for my answer,i normally only do for the disabled,but scrolling through things,your question caught my eye.im disabled,but dont waste my life crying about it lol.whats the point.The site i give ya is free,have a nice day Colin.
Oct 07, 2010 | Health & Beauty
Anti-freeze bucket is slushy. no heat in car
My guess is that you either have "dead" antifreeze, or too much water and not enough antifreeze in your cooling system for the geographic region in which you live.
The "dead" antifreeze? Antifreeze has a shelf-life, and eventually it quits being effective, leaving it without the ability to resist freezing or boiling over. Check the specific gravity of the liquid in the overflow bottle. A tester costs about five bucks, and you will know in seconds whether your coolant needs to be replaced.
As a mechanic of thirty-five years' experience, I can tell you that if your antifreeze is freezing and you don't live in Alaska, your antifreeze is too weak, and you need to replace it. If I have helped you, please remember to vote/comment.
Feb 16, 2010 | 1996 Buick Century
Overheating
water pump ,its a plastic impeller and its loose on the shaft ,,,,,had one a while ago exactly the same but the first time i came across this on a saab i done the same as you ,changed everything ,felt a right you know what
Sep 01, 2009 | 2002 Chrysler PT Cruiser
Roper Refrigerator - manufactured 12/99 - RT18DKXH W00
tata75,
Happy to assist you,
you said,
For the past three days, water has been leaking/freezing at an alarming rate. The freezer had about 2 inches of ice built up and the bottom of the refrigerator is holding water, too. Both crisper s were FULL of water. I don't know if the ice maker connection is broken or what. Looks like I have to cut off the cold water completely to the sink to get it to stop.
Sounds like the ice maker or its line is leaking the water to me. And obviously it will freeze in the freezer.
You need hands on service.
Our site provides service companies in your area.
bless you,
Please give me a good rating before you sign off
Thank You
Sep 08, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
GE GSH25IHRB WW
My water line freezes. I have even had the door replaced and with the new door the line freezes. I use a hair dryer to warm it up and melt it. It's a pain, but saves me from buying a new refrigerator. (Which would definitely NOT be a Hot Point).
Feb 24, 2008 | Hotpoint HSS25GFP Side by Side...
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
