Question about Stanley Utility Knife
I cannot open the front of the utility knife to replace the blade on model 10-788. Can you help me.. I can open the storage area but not the blade area to replace the blade.
I was able to find the answer on another site. It is really simple when someone tells it to you. You push the blade all the way out then you can push the yellow button and it comes out.
Posted on Sep 07, 2009
How to open stanley fatmax knife 10-778 TO CHANGE THE BLADE. thank you
How do I change the blade on the quick change/instant change knife? Warning: Blades are sharp and can cause serious injury. Be extremely careful when handling blades. Wear eye protection and dispose of used blades properly, such as wrapping in duct tape.
FULLY EXTEND THE BLADE.
Press down and forward again on the slide button until the button is in the full front of the top slot (0 through 3 in the below picture).
Note- the blade must be extended beyond the 3rd detent position. This will cause the slide button to remain in a down position, allowing the blade release button to operate.
PRESS AND HOLD THE BLADE RELEASE BUTTON ON THE FRONT SIDE OF THE KNIFE. (Step 4 in the below picture)
Note- if the blade is not fully extended beyond position 3) , the blade release button will not work.
Remove the old blade carefully.
Insert new blade.
NOW, RELEASE THE BLADE RELEASE BUTTON.
ENSURE THE BLADE IS LOCKED IN PLACE. If the blade does not retract, try carefully giving a slight tug on the blade to reseat.
Jul 13, 2011 | Stanley Fatmax Xtreme Retractable Utility...
I just purchased the FATMAX Utility Knife -- Looks nice, but how do I load the blades? Better yet, when I load the cartridge (finally figured that one out on my own) I can't get the blade to...
the blade section pivots to swivel when doing that it allows you access to the blade storage area that holds up to 7 blades, if the extra blades arent in place perfectly the handle won't close properly, if your problem is with the blades themselves, make sure that the slot in the blade is aligned with the holder perfectly
May 14, 2011 | Stanley Utility Knife
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Stanley 10-801 utility knife. How do you change the replaceble blade?
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
Nov 26, 2010 | Stanley Garden
I can't open or refill the fat max. Lost the instructions.
If it is a 10-816 then Knife swivels open for easy blade change and clean out - no tools required, much like 10-999
If it is a 10-778, you don't really open it. You press little button on left side, behind the blade wiper, and this releases blade. Push red button on rear of knife, to open blade storage
if it is a 10-999 then press the button on rear and rotate the two halves.
Oct 29, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Just purchased a Stanley FatMax 10-778 retractable knife. Cannot figure out how to load the blade for use.
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Mar 20, 2010 | Stanley Fatmax Xtreme Retractable Utility...
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
Stanley  Utility Knife  Logo
840 people viewed this question
Top Stanley Cutter Tools Experts
Ivan
Ivan
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Stanley Cutter Tool Expert? Answer questions, earn points and help others
