Question about 2wire (1000-400108-001) Router
Can connect to 2wire, but can't browse
All of a sudden after moving, can connect to new 2wire, but can't browse.
    Problem Solver:
  • 5 Answers
What is the ip address you got from the 2wire router. ??
Try release and renew for new ip. Clear the cache and temporary internet files, and then try pinging the router's gateway ip and check . If pinging. then ping any website's ip address. if successful then try going online. Else you need to power off and power on your router and then try again.
Posted on Sep 07, 2009
Who do I find the WEP number on my 2wire mode?. I trying to hook up an xbox360.
Try to connect to the web gui of the router. Most of the time this is done by browsing to 192.168.1.1 then if you've got the routers password you can view the security settings.
Mar 03, 2011 | 2wire Computers & Internet
My 2wire product seems to need resetting every few minutes. As soon as it's unplugged and plugged back in, it works. However, after a few minutes, it loses connection again. Is this an issue with my ISP,...
  • Re-run the Setup Wizard using one of the following methods if you are unable to browse the Internet:
  • Re-run the HomePortal Setup Wizard from the HomePortal CD.
  • Re-run the HomePortal Setup Wizard by going to http://homeportal/setup (http://172.16.0.1/setup) in your Web browser.
  • (For Windows only.) Re-run the HomePortal Setup Wizard by clicking Start > Programs > 2Wire Gateway > Run 2Wire Setup Wizard.
If required, make sure that you are using your unique username and password. If the problem persists, contact your ISP to verify your connection type and login information (if necessary). After verifying your connection type, also verify that you are using the correct keycode by referring to your HomePortal documentation or by visiting http://www.2Wire.com/keycode.
Nov 04, 2010 | 2wire (1000-000057-000) Modem
I have moved to new home. I am using 2wire wifi
you can check if the ethercable is loose or if you have a spare ethernet cable (rj45) you can replace the one that youre using
Jul 14, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
2wire 585 forgot password and need 2 config have no phone number to change password
f you don't know the system password for the twowire it has a factory reset button near the lan ports
* Hold down the reset button on the back for 30+ seconds.
* Upon releasing the reset button, the router resets itself to factory settings.
* Connect a computer to the 2700HG-B and browse to the URL http://192.168.1.254/
* Enter a new password, confirm it and enter a password hint at the bottom of the page, in case you forget the password.
* At this stage you might receive a "Page Not Found" error, but the password appears to be set successfully.
* To continue, manually browse to the url http://192.168.1.254
* Home Page (summary)
* Run System Setup Wizard
* Enter key code 5225 2374 WG62 22AS BJ7P (from http://www.2wire.com/?p=268) to set up manual config
-> Next
Choose TIme Zone -> Next
* Enter ISP set up details
* For most UK ISPs this will be
Connection type = PPPoA
VPI = 0
VCI = 38
ATM Encapsulation = VC-Mux
For Be /O2 users only
VPI = 0
VCI = 101
ATM Encapsulation = LLC
Exit Registration when connected to Internet
If this helps you plese rate and vote
Feb 25, 2010 | 2wire 2700HG-B Router (2700HGB)
2Wire Gateway seems to be stuck in a reset loop
there is most likely a burnout on the system board. you will most likely have to buy another one
Aug 11, 2009 | 2wire (1000-000057-000) Modem
2wire portal router, after year of wireless connect, stopped
it could be that the wireless part of the unit has failed but to test, can you make sure and try while sitting very close? Also, check for any new appliances close by causing interference
Jul 08, 2009 | 2wire HomePortal® 1800HW Router...
2wire 2701hg-b on mac browsing great, bittorrent bad...
Try to look for MTU settings on your 2wire router. Reduce that to 1492 then do a power cycle. Check if that helps your download speed
Jun 10, 2009 | 2wire 2700HG-B Router (2700HGB)
Hi! im conencted wirelessly but i cannot access some websites
well if you can browse the net with .net and not .com
you should check with your service provider, they must have blocked the .com domains.
Jan 27, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Trying to connect Wireless printer
Will it connect without security. Try it out and let me know what you get.
Jun 13, 2008 | 2wire 2700HG-B Router (2700HGB)
LOSING SIGNAL ON 2WIRE1800HG
first power down the router and switch it back on after waiting about 30 seconds.
Did you move anything around the house close to the router which might cause interference. Microwaves and TV's are rogues when it comes to interfereing with wireless signals
Mar 04, 2008 | 2wire 1800HG Router (RG1800HG00)
2wire (1000-400108-001) Router Logo
372 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
