Question about Maxtor Hard Drive
Maxtor 1TB hard disk in the sky HD box failed
I was using a maxtor 1TB hard disk in the sky HD box. It developed some problem. Now the hard disk is not responding. It is not recognised by the PC also. Please help.
  • lkmishra Sep 06, 2009
    I tried this already. The hard disk is not recognised by the USB cable or the internal pc sata cable. It didn't find the drive at all. I wish to copy the data from the harddisk also.
    President:
  • 2,600 Answers
I would like to try something here. I would like you to hook the hard drive up to your computer either through the enclosure or better if you have a usb adapter that simply slips onto the sata connector. Once this is done listen for the tone of the computer recognizing the device. It doesn't necessarily have to be recognized as a hard drive. Now, open the control panel and open administrator tools. Open computer management and on the left pane near the bottom click disc management. All of the discs currently hooked to the computer will show is the right pane whether they are active or not. If the disc shows here than it is alive and can worked with. Right click on the disc in question and see if it gives you the option to "Initialize". Some of these enclosures that have their own firmware will sometimes de-initialize a hard drive that has been previously activated. If this is the case, then you can "initialize this disc once more and partition it for use. You will lose your data but the drive will be useful once more.
Posted on Sep 06, 2009
  • Chip
    Chip Sep 06, 2009
    I understand, I have been able to access drives that would not normally be recognized unless it was attached to an adapter. Unless the drive is dead mechanically or electrically, it should read in some way. If you can hear the drive "spool" up there is a chance you can get it to be read. The only thing after that, is the controlboard on the bottom of the drive, if it goes South then the only thing to do at that point is right down the information on the label of the drive and try ti find another controller card. Good luck to you. There are companies that can pull the info off the drive by taking it apart in a clean room and placing the hard drive discs on a spindle and reading the data with a special rig. It is pretty expensive depending on how much data you have to recover.
Starts to spin then stops
Either the power supply is failing, or the drive has gone defective.
Check with IOmega, it's probably under warranty.
If it isn't, open up the casing and see whose drive (ie, Seagate, Samsung, Maxtor) they used, because the drive itself may be under warranty by the manufacturer.
Before doing that though, connect the drive inside your PC and see if it works.
If it does, just permanently mount it in there because the external boxs' power supply is shot.
If it works in the PC and you really need it to be external, just buy an external hard disk enclosure.
They are about $30 in most places, and that'll FixYa right up!
Apr 11, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
My hd maxtor basics 1T tries to start but fails. I tried to change usb pc etc.. semza result. you have an idea? thanks
If the hard drive fails to it may be because the usb port is not giving sufficient power to boot.
You should try to plug the hard disk with the usb cable and with the power cable to electric power. This could give the hard drive sufficient power to boot
Mar 24, 2011 | Maxtor BASICS Personal Storage 3200...
Where can I find an online copy of the Sky+HD box "User Guide" please
Click the following link or cut and paste it into your browser:-
http://www.sky.com/helpcentre/export/sites/www.sky.com/helpcentre/tv/anytime-plus/__Content/hd_manual.pdf_1314843347.pdf
I've assumed you're asking about the regular Sky+ HD box and not the Sky+ HD 1TB box, if I'm wrong then use the next link:-
http://www.sky.com/helpcentre/export/sites/www.sky.com/helpcentre/tv/anytime-plus/__Content/1TB_Manual.pdf_1314843347.pdf
I hope that my free answer has been prompt and helpful, if so then please take a brief moment to rate my reply.
Mar 07, 2011 | Televison & Video
My Maxtor 3200 possibly has failed. The green light does not come on and my computer no longer shows it connector asa ext HD. Any recommendations.
I agree that it has failed.
Get the model-number and serial-number from the label on the disk-drive (by opening the enclosure) and use the "check warranty status" utility on Maxtor's web-site, to see if the warranty still is valid. If it is, Maxtor will repair/replace the unit, at minimal cost to you.
Nov 01, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I have a maxtor III usb 2.0 500 GB external hard drive. the light on the front goes out and works sometimes. when the light goes out the external drive gets disconnected . i checked for loose connections....
Possibly, the USB is not receiving current enough and occasionally it resets the USB interface. Try connecting it to another system, or to a powered USB host, and see what happens.
Another possibility (but you'd need to disassemble the external enclosure and connect directly the disk inside to a SMART-capable motherboard) is that the hard disk is developing a fault.
Apr 15, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
Hard Drive not accessible, now not recognised by computer
Do you have another computer you can plug it into? The problem could be with your USB. If it is, see what updates you installed and then removed that may have affected that. You can also go to the manufacturers web site and download the original firmware or updated firmware files.
Dec 12, 2009 | Maxtor Hard Drive
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
Maxtor Basics external portable hard drive not getting detected
Right Click on My Computer, click on Manage, go to Disk Managment, if the drive is available you will see it there. Check to see if it has a drive letter assigned to it, if not right click on it and choose Change Drive letters. Make sure you are on the external drive though, you don't want to change your C drive accidentally. It should pop up in My Computer.
May 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Maxtor Hard Drive Logo
456 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
