Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
How to wire 1 plf 1504d heater
Can't find instructions
  • Anonymous Jan 14, 2008
    my fahrenheat thermostat is a double pole (fta2a) has two red and two black but the convection baseboard heater only haws one red and one black. How are these connections to be made??????
    What size breaker should I use for a 2000 watt/240v heater??? I currently have 12/2 wire as a supply wire from the box
I have the solution, finally after looking for 2 days.
First off, I couldn't quite put it all together based on what I was reading. I finally tracked down the Fahrenheat web site (www.fahrenheatpro.com). And called tech support (800) 452-4179.
To wire 2 BB units to 1 tstat.
1. Use #14 wire for 0-12 amps, #12 wire for 12.1 to 16 amps and #10 wire for 16.1 to 24 amps.
2. I have a 12/2 wire going from the tstat to BB#1 and another 12/2 wire going from BB1 to BB2.
3. Onthe left side of the heater, you will have 2 sets of black wires tied together with a nut (on right side it's 2 sets of Black/Red wires). You can use either side of the heater. For the purpose of explaining this, lets use the left side, 2 sets of black wires.
4. Undo one of the sets of black wires (it doesn't matter witch), the other set will be left alone.
5. Take the black wire coming from the tstat and tie it into one of the black wires from the heater and the black wire going to the second BB unit. So you will have those 3 wires tied together with a nut at the 1st BB unit.
6. Take the white wire coming from the tstat and tie it into the other black wire from the heater and the white wire going to the other BB heater. Again, you will have 3 wire tied together here.
7. At the second BB unit, tie the black wire coming from the 1st unit to one of the black wires in one of those 2 sets of black wires. Again, only undo 1 set of wires at the 2nd unit, leave the other one alone. Tie the white wire coming from the 1st unit to the other black wire.
8. Make sure ground wire in grounded at the tstat and at both BB units.
Hope this helps...... If I was less clear than I hoped, call tech support and they will walk you thru it....
Kevin.
Posted on Oct 16, 2008
How do you wire a plf 2004 heater using a remote thermostat?
Posted on Jan 05, 2008
  • 625 Answers
240 volt wall mount baseboard heater. at either end of the heater is a service plate. it may also have an integral thermostat on one end. feed your line into the side with the thermostat. the thermostat has two wires a black and a red, with similar wire colors going to the element. wire your line on one red and one black on the same side of the "stat." the not connected to anything side of the "stat." the rest of the heater is series wired to the overload and element. (factory wired) no need to touch anything here.
Posted on Dec 09, 2007
Water heater blinks 7 times. I don't get any hot water. Model # is MITW4056FBN
Hope this helps..I have also attached a link that may be useful.
No Hot Water
REASON REMEDY No power Check fuses or circuit breaker, replace or reset. Check with utility if necessary Wrong wiring connections at heater terminal Correct according to manufacturer's instructions Leaks around heating elements (1) Tighten element (2) If necessary, clean and replace with new gasket Loose wiring connection Locate loose connections. Clean carefully (remove all oxidation). Reconnect properly Lightning Inspect: (1) fuse (or circuit breaker). (2) Heater elements, and (3) thermostat, replace if necessary, see "grounding instructions" below High voltage Check utility for correction Short Locate short circuit and correct Wrong piping connections Reconnect pipes to proper fittings according to manufacturer's instructions Undersize service wiring Check with utility co. or electrician Improper calibration Replace thermostat Faulty thermostat Replace Faulty thermal cutout Replace Open thermal cutout Reset Top heating element burned out Replace
http://www.bradfordwhite.com/sites/default/files/product_literature/48494-A.pdf
Jan 13, 2018 | Water Water Heaters
I have 2 fahrenheat plf series heaters how do i wire them up to 10/2 wire. i have 2 black wires with a wire nut, 1green with a wire nut and a black and red wire with a bell crimps where does my white...
If I understand you correctly the two black wires (from heater) are caped off with a wire nut and the black and red with crimp ons are attached to something? If so attack the black wire to one of the black caped off leads from heater and the other caped off wire to the white wire from the 10/2 cable. Make sure that that 10/2 wire is attached to a 2-pole breaker not larger than 30-amps.
Sep 04, 2011 | Fahrenheat Electric Hydronic Baseboard...
Hello Fixya Guru ! I am in the process of installing several Marley PLF series 2000 watt/ 240 volt electric "Hydronic" baseboard heaters. I am using 10/3 bx with a 30amp breaker. To my...
You are correct that these heaters use a two-wire 240 volt supply, and the neutral is not needed.
2000 watts = 240 volt x Amps ==> Amps = 8.3 amps
30 amps x .8 safety factor = 24 amps
24 amps / 8.3 amps = 2.9 heaters per 30 amp breaker (3 heaters should be okay)
More info, pls let me know.
Charlie
P.S. Where does the 2880-watt number come from ?
P.P.S. There has to be a ground bus-bar in the panel -- if it's a main panel (not a sub-panel) the ground buss and the neutral buss are connected in the panel. Could you clarify what you have in the panel.
Jan 11, 2011 | Fahrenheat Electric Convector Baseboard...
Led 1 and led 2 both are red, what does that indicate?
Led 2 flashing indicates the the computer is undergoing POST (testing components). If it flashing then something is wrong, usually the computer beeps a cumber of times which translates to a code eg ram error.
When led 2 is stable, the computer completed POST and is booting up through bios and then the OS.
Led 1 on which means the computer is receiving power.
See Manual: http://global.aopen.com/userdownload_List.aspx?RecNo=10062&Model=1258
Nov 30, 2010 | AOpen i945Ga-PLF (918EA10I40) Motherboard
I'm replacing a non-hydronic electric baseboard heating unit with a Fahrenheat hydronic one. My old unit was 240v using 2 conductors plus bare ground wire. The fahrenheat (PLF series) unit's instructions...
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Jan 06, 2010 | Fahrenheat Electric Hydronic Baseboard...
No i didn't. I need instructions for wiring a
you have baclk and red wire supply and a black and red wire to load (baseboard).
your switch will have 2 black and 2 red.
connect blk supply to 1 black on switch ( it doesn't matter which one)
connect red supply to 1 red on switch
then
connect black from baseboard to black switch
connect red from baseboard to red switch
if multiple baseboards that have several loads at thermostat then just connect baseboard blacks together and reds together before connecting at switch.
Oct 17, 2009 | Heating & Cooling
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
1,595 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
