Detect my pc can't detect external hard disk and any china mobile
  • Lawrence Costa May 11, 2010
    Have you looked at "my computer" which can show all drives That can be detected. Connect the drive and reboot the computer.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 153 Answers
Hii
Certain times its does happen on windows operating system. Kindly follow the steps below this wud surely help u out.
Try checking the "disk management"
to go there:
right click "my computer"
click "manage"
now theres a new window that popped up, click the "disk management"
you should see your removable disk there, once u see ur ext hard disk, right click and assign a drive letter, your problem will surely be solved.
@ CHINA Mobile
Try This
Goto > MY COMPUTER > Right click PROPERTIES > HARDWARE tab > DEVICE MANAGER
Here you will be able to see ur china mobile's port with a Yellow Question mark icon > Right Click and Update Drivers.
NOTE: You may or may not find drivers for such phones, plz also check if ur mobile phone has a option using ur cell phone as USB Data Manager.
Hope it helps.
Regards
Posted on Sep 07, 2009
External hard disk
You should not need a disk to get an external hard disk initialized. Did you try to plug it into your PC and see if it detects it?
Sep 09, 2013 | Verbatim 1TB PRTBL USB 12.5MM-3.0 2.5...
My transcend storejet 25m2 does not detect my xp sp 2 pc what the **** i can do
Good day..!!Try to check at the disk management,then change drive path or mount,then ist already detected in my computer..thanks
Aug 17, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
My son threw the hard disk and its not being detected anymore. The hard disk makes a screeching noise when plugged in. Looks like the disk is done. Any solution ???
Hard disks DO NOT like hard knocks, this hard disk is broken, especially when they make loud noises.
It can't be fixed, by us mortals. Cheaper to get a new one.
Apr 20, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit: www.hp.com/go/techcenter/startup
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Feb 01, 2011 | HP Pavilion dv6000z Notebook
Hard disk not recognised
When a hard drive makes a clicking noise, it is faulty. The clicking noise is the heads swinging back and forth. This hard drive is dead and the data is lost. If you desperately need to recover your data, there are companies that can recover and copy your data from faulty hard drives BUT it will cost you an arm and a leg for their services.
May 15, 2010 | Hitachi 120GB Hi-Speed Mobile Disk USB 2.0...
I got an external driver with one side Mobile Disk and other side hd-337-combo can somebody help me to find the drivers cause i tested the hard disk in my PC and with the mobile disk my pc says USB Device...
Mobile Labs provides enterprise-grade, next generation mobile application testing tools. With a focus on security, agility and affordability, Mobile Labs delivers solutions to help you deliver quality mobile apps for Android, iOS and Windows platforms while also helping manage mobile devices in a private, secure cloud.
Mobile Device Testing Mobile App Testing Mobile Labs Inc
Jun 07, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
External Hardisk Maxtor 4 One Touch not detected
Have you tried different USB cables with the drive? If the drive is self powered (no ext power supply) which I think that one is, then it needs a really good cable to draw the 5 volts from the USB port. If you have tried a known working cable, then it could be the USB controller or the disk itself. You can buy the USB box on eBay really cheap and move the drive over.
Apr 13, 2009 | Computers & Internet
No mobile hardeware shows on computer
go to the mobile service point or mobile hardwae point.and show it.
Mar 06, 2009 | Microsoft Windows XP Professional With...
System not detecting hard disk
is that a sata drive or ata?...if ata, try to change the IDE Cable that connected to your Hard drive?..
Feb 26, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Computers & Internet Logo
176 people viewed this question
David Payne
David Payne
