Question about Microsoft Xbox 360 Wireless Controller
360 right stick gets stuck when tilting left
I first noticed when playing a shooter: when I tilt the right stick left (for instance to turn around, the view stutters, like the signal was going on and off. The result is it turns a bit then stops and starts turning again. All the other directions work great.
It doesn't feel as if something is underneath it blocking the stick, I tried restarting the console, changing the batteries (I use rechargeable AAs), what can I do?
  • 12 Answers
SOURCE: Lights Flashing On Xbox 360 Controller
So the sytem is working but the controller isn't connecting? Try fresh batteries, try removing things that might interfere with the controller (cell phones, large metal things between the controller and the xbox, portable house phones, bluetooth devices), try another controller if possible (borrow one).
Posted on Jan 01, 2008
SOURCE: my xbox 360 won't turn on
I know what to do.... it happened to me, but I fixed it. Ok you will need a peperclip for this to work. Take off the faceplate of the 360. And then what should have been the powerbutton, use the paperclip to hit it. It should turn on, then you can put the faceplate back on.
Posted on Jun 28, 2008
  • 174 Answers
SOURCE: xbox 360 will play movies but not games
you cannot just replace the old dvd drive with a new one, you need to take the key from the old drive and then place it onto the new drive so it will work. all xbox 360 drives have a security key. If you still have your old drive then you may be ok and it may be that a technician can do the work for you.
Posted on Jan 18, 2009
  • 19 Answers
SOURCE: 360 reads game discs but it won't play game and it says play DVD
The problem is that the laser is either dying out, is dirty, or is not getting enough power.
so try to fix it using these steps...
- first open the 360 and pull out the dvd drive and open it up too.
- clean everything out good with compressed air, and q-tips dipped in alcohol.
- now you need to adjust the power going to the laser.Sometimes you may have to try multiple settings before getting it justright. Just keep adjusting the resistance lower and lower until itworks.
- if you tried multiple settings and still get the errors, then either get a replacement drive, or a new laser for it. Click Here for how to properly install the new laser.
- if you get a replacement drive, please not that there is a key in the pcb of the drive that must match the key from the motherboard, so you must either spoof firmware with the key, or swap out the old pcb board and put it in to the new drive.
If you need more dvd drive repair help click here
Posted on Mar 06, 2009
  • 39 Answers
SOURCE: hey, my xbox 360 controller's right analog stick is broken
you need a new controller.
Posted on Dec 15, 2009
Even after numerous on off sequences I still get the same error code of xerox phaser 8560 error code 07 010 43.22845
The printhead is stuck in the tilted position or is not able to tilt forward to the print position, due to problems:
Has ink spilled ink around the printhead that prevents it from moving to its center position? You should be able to push the printhead right to left. Clean the printhead area. Is the printhead stuck to the Wiper Blade? Check the process drive gears for obstructions. Ensure the gears are correctly aligned and homed. Has ink spilled on the Head Tilt gear drive train? Clean the gears area of ink.
Apr 23, 2014 | Xerox Phaser 8560DN Printer
This error indicates the Printhead was unable to tilt normally on its axis. Check for spilled ink around the printhead that prevents it from moving right to left. The printhead could also be stuck to the wiper blade if the printer was turned off during a cleaning cycle. If you turn the x-axis motor does it move the printhead forward and backward? Check the process drive gears for damage and ensure the gears are timed correctly. Check to see if ink has spilled on the head tilt gear train (left side of printhead)
Feb 02, 2014 | Xerox Phaser 8860MFP/D - Multifunction -...
The printhead is stuck in the tilted position, or is not able to tilt forward to the print position due to obstructions.
Has ink spilled around the printhead that is preventing it from moving? (you should be able to push the printhead from left to right) MAKE SURE THE PRINTER HAS BEEN OFF FOR 30 MINUTES BEFORE YOU TOUCH THE PRINTHEAD !!!
Check the process drive gears for damage and make sure they are aligned correctly.
Has ink spilled into the tilt gears assembly or on its drive train? (left side of printer)
Nov 12, 2013 | Xerox Phaser 8550DP Printer
Problem with logitech dual pad right analog
Try to disassemble the pad. Reseat the analog stick and re-assemble the pad.
May 12, 2012 | Logitech Dual Action for Pc (963292-0403:)...
Hi. Our 8560MFP has come up with the error code 07,010.43:93096, plus the message "power down error - head not parked" - is this something we could look at ourselves or do we need professional...
7,010.43 Printhead is stuck or is not tilting properly over the cam.
Initial Actions
• Check that the Process Drive gear train is properly homed.
• Check for obstructions or ink spills around the Printhead.
• Verify the Printhead travels smoothly from left to right.
• Check the Printhead Restraint Arms.
• If the problem persists, follow the procedure below.
Table 1 7,010.4x through 7,015.4x Troubleshooting Reference Table
Applicable Parts Wiring and Plug/Jack References
Process Drive, PL 4.0 Right Side Harness / I/O Control, Figure 8
Head Tilt Solenoid, PL 4.0 Left Side Harness (2/2), Figure 5
Head Tilt Gear, PL 4.0
Restraint Arms, PL 2.0
Head Maintenance Clutch, PL 4.0 I/O Board (2/2), Figure 10
Table 2 Printhead Restraint Fault 7,010.xx through 7,015.xx Troubleshooting Procedure
Step Questions or Actions Yes No
1 Reboot the system.Does the error persist? Go to Step 2. Complete.
2 Check the Printhead Lock Arms. Go to Step 3. Repair or replace Do the arms rotate correctly? the Printhead Restraints
3 Check for ink spills around the Printhead Go to Step 4. Remove ink spills or obstructions.
and Printhead Tilt Gears. The Printhead
should move when pushed left or right.
Is the area around the Printhead clean
and unobstructed?
Jul 04, 2011 | Xerox Phaser 8560MFP Laser Printer
Inserted disc into the xbox 360 elite 120 gb and now the disc has got a deep continous scrached ring around the face of the disc now the xbox 360 will not read the disc so im not able to play on it.
your dropped or tilted your 360 while playing the disc. this happens. there is nothing you can do except return it if you have a reciept for another one or buy another one. if you drop your 360 while its on with a game inside or you tilt it the disc inside will scratch up because of the spinner.
Jan 05, 2010 | Microsoft Xbox 360 Elite Console - Black
Xerox 8400 error 07.010.43:52882
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward to the print position, due to problems.
Do the printhead lock arms rotate correctly.
Has ink spilled ink around the printhead that prevents the printhead from moving to its center position? You should be able to manually push the printhead right to left.
Does the X-axis motor drive the printhead to it’s center position (so it can tilt forward)?
1. Check the process gearbox for obstructions
or damaged.
2. Ensure the gears are correctly aligned and
3. Verify the process shaft and drive module
shaft are at their home positions.
Has ink spilled on the head tilt gear on its drive train (near left side of the printhead).
Aug 30, 2009 | Xerox Phaser 8400 Laser Printer
Xbox 360 controller left analog stick
If you bought it brand new, contact Microsoft ASAP.
Otherwise, no luck. Just an unfortunate side affect of playing a 360.
Apr 04, 2009 | Microsoft Xbox 360 Wireless Controller
How do you do a 360 on mx vs atv ?
When on a ramp or a slope hold both "c" and "z" buttons and quickly do a "left-right" or "right-left" tilt of the joystick. It works best if you do it while still on the ramp/slope (i.e. before you actually go airborne) and keep holding the stick to the side you are turning. It is quite hard to land though. i hope this helps!
Dec 16, 2008 | Nintendo Mx vs. ATV Untamed Wii for Wii
PS3 Controller Jams
Have you found a solution to this problem? I have the same issue for the right stick. I played the SKATE demo a couple of times and that exaxt thing happened to me. Help please.
Apr 25, 2008 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Wireless Controller Logo
162 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
