Question about Eliminator Hudson Sprayer - 1 Gallon, Model# 30161
How to remove lid
I cannot unscrew the top to fill it up
  • 202 Answers
The only way that I know of is to hold the bottom part (jug) securely and turn the pump handle. If you put some pressure on there and just hold firmly it should eventually start to unscrew. You need to push the pump handle down as far as it goes and it will lock into some "ears" on the pump assy so it will turn the pump assy as well.
Posted on Oct 25, 2009
How to oil Highlead sewing machine
which model do you have? tip the head back & fill the sump to the high line on most flats. overlocks you need to unscrew the top cap & fill untill the sight glass is full to the top line. some require you to oil daily check the manual
Jul 12, 2014 | Sewing Machines
How do I get the mill open to fill it and put in batteries?
d65b8aa2-bda9-4fd2-810b-bf61e63e797e.jpg pepper mill
e206c9bf-aafd-400c-9672-b16614dd71b0.jpg Unscrew top where clear part attaches to metal. 55cea22b-5cf2-484e-9228-41c8146cea32.jpg
To load batteries, unscrew bottom. Once open, load fresh batteries. If mill fails to operate, unscrew bottom again and flip wire bale in opposite direction.
Jul 05, 2014 | Wolfgang Puck Salt & Pepper Mill Set
Washing machine keeps filling with water even when washing machine off. can hear the water coming through the drawer at top and fills into drum. had to out cold water valve off
You will need to replace the inlet valve inside the washing machine. It is stuck in the open position. It's a fairly easy to replace. you will just have to unscrew the top[ in the back and lift the lid to access.
May 28, 2011 | LG Washing Machines
Hi,I have a 1998 bmw 328 sport and need to know how much oil is required to fill the engine from empty(do an oil service) and also how to top up auto gearbox oil?
fill engine on flat surface, then read the dipstick.
Transmission: raise car. Run car to normal oper temp. while running unscrew top access trans fill screw. nothing should come out. fill it till it does....it is now full.
For dummies: No, there's no trans dip stick. No, unscrew the top access plug while cold and not running....most of it will drain out.
For flat out stupid people, those with an IQ of room temp on a cold day: Take it to jiffy lube so the car doesn't fall on your head and crush it.
Nov 17, 2010 | 1997 BMW 328
Can't figure out how to fill this..
open the pack, there will be a large screw top cap. unscrew it to open it. fill from there
Apr 24, 2010 | Camelbak ThermoBak 3L
I have a hudson classic sprayer and have no instructions.
The pumping mechanism should unscrew from the plastic bottle. Push the handle all the way down and try to unscrew the pump while holding the bottle steady.
Jun 16, 2009 | H.D. Hudson 2g Yard N Garden Sprayer
Topping up gearbox oil on 99 Hyundai Lantra (manual)
You can actually do it from the top if it is similar to a 2001 Elantra??? On your right center of the tranny, there should be two big bolts I believe a 17mm one on the bottom left the other top right of the other. The bottom left is the drain plug the top right is where you fill it. If you want to make things easier you can remove the air cleaner and the air cleaner housing then unscrew the sensor on top of the tranny you can poor it in from the top. You will need to then unscrew the fill hole (Top right bolt) Pour the lube in to the hole where you had taken out the sensor until it pours out of the fill hole. Sounds like more work but by doing this you will avoid making a mess trying to fit the squeeze bottle into the tiny hole. Hope this makes Sense????
Apr 29, 2009 | 2001 Hyundai Elantra
Hydraulic Fluid Level (Checking and Filling)
hello darrell. yes you just unscrew the plug and fill it full.
Apr 15, 2009 | Toys
Engine oil
theirs a big black cap on the top of the engine. just unscrew it and fill. it should be located on the left side by the injection system/airflow tube.
Feb 11, 2009 | 2000 Hyundai Accent
Eliminator Hudson  Sprayer - 1 Gallon, Model# 30161 Logo
664 people viewed this question
Top Eliminator Garden Experts
Dennis Key
Dennis Key
john h
Are you an Eliminator Garden Expert? Answer questions, earn points and help others
