I don't know what kind of battery I need for the film camera or if I even need one at all. I was told I needed one, but I can't find a place were the battery would go. It is a pretty old camera and I have tried taking pictures with it and it works but I don't know if the pictures are going to come out right without the battery. Please let me know if you know what kind I need and where it goes if I even need one. Thank you.
Your camera uses 2 x CR123 batteries; they fit in a chamber on the underside of the camera beneath the right hand grip.
The camera is an autofocus fixed lens SLR and batteries are essential.
You can view a .pdf manual at the web address below: it's for an IS-20dlx but it's the same camera as the IS-200. Your model had different names depending upon where in the world it was sold. I recommend that you save the manual to your pc as there's no guarantee how long these resources will remain online for.
http://zuserver2.star.ucl.ac.uk/~rwesson/esif/om-sif/is-series/manuals/is_20_dlx.pdf
Please return the favour by rating my answer.
Not personally familiar with that camera model, but most older SLRs did require a battery. Those usually can be located on the bottom of the camera where there is what looks like a slot for a large screwdriver. It is actually to be unscrewed using a coin -- nickel/dime/quarter and will unscrew revealing a rather deep space (for those used to today's digital batteries). The battery required might not be too easy to find, but a large camera store might be able to locate it in their supplier's catalog if they could see your camera (or maybe even from the model number).
This takes a 3V Lithium cylindrical battery type CR123A, DL123A from any manufacturer. It goes in at the bottom of the camera under the shutter release (right hand side) as you look from the rear of the camera.
Chemistry of battery:
Lithium, High power, non-rechargable
Voltage:
3.0 V
Weight:
38 g
Dimensions:
84mm x 17mm x 119mm
Shape:
Cylindrical
Voltage:
3.0 V
Weight:
38 g
Dimensions:
84mm x 17mm x 119mm
Shape:
Cylindrical
Voltage:
3.0 V
Weight:
38 g
Dimensions:
84mm x 17mm x 119mm
Shape:
Cylindrical
Voltage:
3.0 V
Weight:
Dimensions:
84mm x 17mm x 119mm
Shape:
Cylindrical
