Question about Nokia 6500 Slide Cellular Phone
I forgot the security code
I forget the security code in my mobile that i buy it new 6500 slide what can i do to fix the problem
I am forget my password how to reset my 6500 nokia phone
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 17, 2012 | Nokia 6500 Slide Cellular Phone
I forgot security code for 6500 slide nokia
Security code lost means, get the master reset code for that one.......
you can get the master reset code for your Nokia model mobile, through this site http://www.prounlocking.com/nokia-dct-master-code-service/rs8wp10/ , It has the best services for the master reset codes and unlocking codes for mobile phones.........
Jun 15, 2011 | Nokia 6500 Slide Cellular Phone
Forgot my security code for nokia 6500 slide
You can use the Master Code to reset the security code, master code is unique for every nokia phone use nokia loxk code service from http://www.nokialockcode.com/
May 12, 2011 | Nokia 6500 Slide Cellular Phone
My IMEI number is :358675010131743 Phone model : Nokia 6500 Slide. I forgot my security code. Please help me to hard reset my phone. Thank you.
If you forget the security code means, you can get the master reset code,
Visit this site http://www.onlinegsmunlock.com/nokia-dct-master-code-service/rs7wp10/
Mar 16, 2011 | Nokia 6500 Slide Cellular Phone
Lost secrity code nokia 6500 slide
SECURITY CODE:
If you are talking about the security lock code to enter into the phone then once it is lost nothing can be done except flashing the mobile . Because if anybody can give the security code created then who ever who steals your phone can get into it and get your valuable information.
So as safety precaution to avoid that they have designed it such that if you forget the security lock you have to reset the mobile memory by flashing the mobile at an authorized service center.So while flashing the mobile all the data in the mobile memory will be lost and you can again start using the mobile.
Feb 23, 2011 | Nokia 6500 Slide Cellular Phone
Forgot security codes nokia 6500slide IMEI:353547021076503
1.Get an unlocking software, connect your phone the system,install the software and use it to unlock or flash the phone.2otherwise unscrew the phone to remove the backup battery for just 30 minutes.fix it back.its ok
Jan 30, 2011 | Nokia 6500 Slide Cellular Phone
L block my nokia 6500 slide, I forgot the security code which I setted. imel is 353076021722809
If you forgot your Nokia Phone's Security Code, you can still reset it by using the Master Security Code of your Nokia Phone. Where to get it? You have to know first your phone's IMEI. To get your phone's IMEI, type *#06# on your mobile. Get the IMEI #. Follow this link. http://nfader.su/ and type the IMEI of your mobile. Click Generate button and the Master Security code of your mobile will be displayed. Enter the Master Security Code instead of Security code on your mobile when asked to Enter the Security Code.
Dec 15, 2010 | Nokia 6500 Slide Cellular Phone
I hv nokia 6500 slide phone.i want to set securty code but i forget old securty code.can u help me to set new securty code.
hi....
in case if you have forgetten your old security code,the only solution is to flash ur phone software from the nearest nokia care,it also updates your mobile software which increases the mobile speed....
thank you..........
Sep 26, 2010 | Nokia 6500 Slide Cellular Phone
Nokia 6500 Slide Cellular Phone Logo
146 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
