Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philips Magnavox 54 in rear projetion TV
I've had my TV for about ten years now and notice the picture is getting more and more cloudy. I tried adjusting all of the settings to clear the picture up, but nothing seems to work. A friend of mine has the same TV and had the fluid in the 3 color guns replaced and the picture looks great.
My question is, can I purchase the fluid and change it my self? I have experience servicing computers and fiber optics communication equipment. So tools and skill isn't and issue, and I know that I can purchase the service manual to guide me thrugh the work.
  • mtndew Jun 04, 2008
    Philips Magnavox PR3052A102 Projection TV needs color. Where do we purchase color or find someone to replace for us?
  • jbertjr Jun 27, 2008
    i just bought a 61'' philips magnavox tv and it is darker and cloudier than my other tv. where to buy fluid and how to fix model#9P6031c101
    Problem Solver:
  • 5 Answers
Be careful doing this because this fluid is poison it s better to be done at the shop.Not an easy job.
Posted on Jul 13, 2009
Try reading this page:
http--www.iwaynet.net-~nesda-ProjCool.pdf
Posted on Dec 14, 2007
    Novelist:
    Champion:
  • 232 Answers
Darrt, it`s a big, messy, dirty job but of course anyone can do it if they decide to do so, you MUST get the service manual but it won`t be all that much help, the tubes have to be removed from the set, it`s usually the blue & green that get contaminated, the service manual will explain the procedure to get the fluid out, (which screws not to remove etc.) it won`t tell you to mark the position of each lateral magnet, it won`t tell you that if you move/break the paint on the lateral magnets that your screwed, that yoke position is critical, etc. because they presume your a tv tech. Be advised that you should NOT use Philips coolant when you get ready to refill your tubes, use RCA or some other brand so it won`t repeat the problem, good luck you`ll need it, if you decide to tackle it ask lots of questions on here, BMW Rider
Posted on Dec 11, 2007
I have a Philips Magnavox 9P6034C 60 in. Rear Projection Television the whit bulb is gone out where do i get another one
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 27, 2011 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox 55" rear projection tv problems
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 11, 2010 | Philips Magnavox 9P6034C 60" Rear...
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Cloudy picture on rear projection tv
Your picture guns and mirror is dusty. You can try cleaning yourself if you know what your doing, but I would let a qualify tech to do it.
Nov 20, 2009 | Philips Televison & Video
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 milleniumtvsvc@gmail.com
Jul 21, 2009 | Philips E-Box FTR9965 DTV Receiver
Bad picture
A 10 year old Rear Projection tv is usually at the end of its life. No such thing as "fluid". Best advice, get a new TV.
Dec 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
What are they talking about when they say you need to change the fuild in your tv. I have 60" philips magnvox that is about 10 years old
The projection TV sets have a coolant that surrounds the CRT picture tubes. It is used to keep them cool when they are lit up. After 5 or so years the fluid gets cloudy and needs to be drained and replaced. If you do it correcly your set will have the best picture you have seen in a long time. Check with the site www.TvRepairKits.com for the fluid and a photo instruction guide.
Magnavox 54" Projection screen TV
Replace your STKs 392-110s with 180s if 020s go with 040s
Oct 27, 2008 | Philips Magnavox 51MP392H Rear Projection...
Phillips Magnavox 60 inch Projection Tv
That model is famous for having bacterial contamination in the CRT coolant causeing halos, and dim pictures with bad overall color issues. You can look into the lens of the CRTs when the set is laying and if the coolant looks cloudy or has any growth there you will notice it right away, and changing the coolant will restore color, clarity and brightness.
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillps magnavox 9P5034 possible bulb going
Sometimes it the coolant that makes the tubes cloudy often changing coolant will make a difference, however I do work for a site that has replacement CRTs If you would like a link they run 135. each with free shipping and instalation instructions
Mar 29, 2008 | Philips 9P5034C 50" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
673 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
